Alternator Restoration Question #1359959
12/27/12 11:23 PM
12/27/12 11:23 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
Just dis-assembled Alt., glass beaded case and want to clean copper center outer ring as well as re-paint center piece.
How do I clean the center piece (copper)?
What color do I paint the center piece? Thanks
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Alternator Restoration Question [Re: 68 Sat] #1359960
12/27/12 11:23 PM
12/27/12 11:23 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
2nd pic
Re: Alternator Restoration Question [Re: 68 Sat] #1359961
12/27/12 11:47 PM
12/27/12 11:47 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Niether the stator or the reluctor were painted. Do yourself a favor. pack it up and send it off to Dixie Restorations. You can thank me later
Re: Alternator Restoration Question [Re: ScottSmith_Harms] #1359962
12/28/12 01:10 AM
12/28/12 01:10 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Can they fix the surface of one that has been glass blasted?
Re: Alternator Restoration Question [Re: 71birdJ68] #1359963
12/28/12 01:12 AM
12/28/12 01:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm not sure how they'd deal with that, best to ask them.
Re: Alternator Restoration Question [Re: ScottSmith_Harms] #1359964
12/28/12 10:23 AM
12/28/12 10:23 AM
SC
Cooda Offline
Cooda  Offline
SC
I'll second what Scott said, pack it up and send to Jim Ridge (Dixie Restorations).
Re: Alternator Restoration Question [Re: Cooda] #1359965
12/28/12 03:53 PM
12/28/12 03:53 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
The color you see on the stator (outside) and rotor (inside) is the insulation of the the wires used for both. If you try to be aggressive when cleaning, you could cause a spot for a short circuit to happen.
Best is to have someone that rebuilds electrical look at these. They will have proper tools to check everything and if needed, rewind and repair as required.
If you do try to clean them, then used something very very non-aggressive so it won't eat the insulation off the wire. If Dixie are doing the job, then send it out to them . . .
Hope that helps . . .
Cheers
Mark
Re: Alternator Restoration Question [Re: Cooda] #1359966
12/29/12 01:31 PM
12/29/12 01:31 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I'll third that
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Alternator Restoration Question [Re: VCODE] #1359967
12/29/12 01:52 PM
12/29/12 01:52 PM
England/South Africa
roelb Offline
roelb  Offline
I sent mine all the way across the pond, Jim did an excellent job. He is a great guy to work with
Re: Alternator Restoration Question [Re: roelb] #1359968
12/29/12 08:47 PM
12/29/12 08:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can do it yourself with a little effort .
Re: Alternator Restoration Question [Re: 62maxwgn] #1359969
12/30/12 12:35 AM
12/30/12 12:35 AM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I am sure Jim is great but I was hoping to tackle
This On my own. Thanks guys
Re: Alternator Restoration Question [Re: 68 Sat] #1359970
12/30/12 01:56 PM
12/30/12 01:56 PM
a12rag Offline
a12rag  Offline
I would then suggest something like dish washing liquid detergent and a soft toothbrush . . . should not harm the insulation on the wires and be able to clean it up pretty good. Just make sure you dry it off well and check the electrical connections prior to reassembly.
Mark
Re: Alternator Restoration Question [Re: ScottSmith_Harms] #1359971
12/30/12 02:37 PM
12/30/12 02:37 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Alternator restored by Dixie restortions:
They do a great job on these..
Re: Alternator Restoration Question [Re: 71redcuda] #1359972
12/30/12 02:38 PM
12/30/12 02:38 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
nr 2
Re: Alternator Restoration Question [Re: ScottSmith_Harms] #1359973
12/31/12 01:30 AM
12/31/12 01:30 AM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
" Niether the stator or the reluctor were painted. Do yourself a favor. pack it up and send it off to Dixie Restorations. You can thank me later............"
does dixie have all the parts to redo on alt.that has 2 different date coded housings.?????? My car is about 90% susvivor so I'll need to restored and correct dates in both half's please post or PM me with his contact inro........And again THANK YOU I ALSO HOPE YOU HAD A MERRY CHRISTMAS AND A GREATER NEW YEAR..........
Re: Alternator Restoration Question [Re: Hemiruss] #1359974
01/02/13 09:50 AM
01/02/13 09:50 AM
SC
Cooda Offline
Cooda  Offline
SC
Call Jim at Dixie and ask. He did at one time have some cores...not sure what he has now.
Re: Alternator Restoration Question [Re: Cooda] #1359975
01/02/13 03:48 PM
01/02/13 03:48 PM
70RT Offline
70RT  Offline
68 Sat - The rotor and stator (reluctor) were originally coated with a tinted electrical varnish that is no longer commercialy produced - at least we can't find it. I had the help of a knowlegeable friend in Detroit not only break down and then recreate the proper tinted varnish but he also constructed a fixture so these parts could be coated in a factory style manner. The center section, or heat sink, that holds the positive diodes (rectifiers) we finish the same way as the front and rear shells. Then most, not all, but most, shells were put through a chromate wash I assume to create longer shelf life for the aluminum parts.
Hemiruss - We do have quite a few odd front and rear alt. pieces in the shop if you need something to replace a mis-matched alternator core piece.
Thanks for the kind words guys we really appreciate it! Scott the carbs coming off this w/e so I'll have it to you shortly.
Jim Ridge - Dixie Restorations (803) 924-6247
Re: Alternator Restoration Question [Re: 70RT] #1359976
01/02/13 08:48 PM
01/02/13 08:48 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I'll give you a call when I can...the front halve is a 70 and the rear is a 76.....Thanks again
Re: Alternator Restoration Question [Re: Hemiruss] #1359977
01/06/13 08:34 PM
01/06/13 08:34 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
here it is after a few hours this weekend. I still have to press the pulley on but not bad for my non concourse 69 Coronet 500...Used RPM and alot of time...
Re: Alternator Restoration Question [Re: 68 Sat] #1359978
01/06/13 08:34 PM
01/06/13 08:34 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
2nd
