3 Speed To 4 Speed #1359941
12/27/12 10:43 PM
12/27/12 10:43 PM
Fort Worth, TX
Dago Red Offline OP
Dago Red  Offline OP
Fort Worth, TX
I only have one stick car and it's already a 4 speed.
A local garage owner is helping his cousin upgrade a 71 Duster. Nice car.
A s/b stroker and an 8 3/4 but it has a three speed (floor mounted)
How difficult to change over to a tried and true Ma Mopar 4 speed and what parts will they need? (A clutch and new flywheel will be necessary too)
These guys a mechanically sharp, they just haven't done any early Mopar stuff. They even tossed out a Chevy guy who bad-mouthed the build. Ya gotta like that!
Pretty please, don't launch into a sales pitch about aftermarket 5 speeds or overdrive automatics.
I'm asking here because this is where the sharp razors hang out.
Thanks in advance.
If You Can't Be Good, At Least Be Colorful
Re: 3 Speed To 4 Speed [Re: Dago Red] #1359942
12/27/12 11:03 PM
12/27/12 11:03 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
If it is a V8 3-speed, all you would need is the 4-speed, shifter & linkage, as the bellhousing will be dual bolt pattern to accept either transmission. We can supply whatever you need.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 3 Speed To 4 Speed [Re: 64dodge572] #1359943
12/28/12 12:15 AM
12/28/12 12:15 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hi Wayne,
Is there a better 3 speed shifter setup available (shifter mech, rods, linkage, etc.) that is a direct replacment for a stock 70-74 A-body unit? Maybe one that the stock shifter handle will work with? The factory mechanisms are sort of junkie.
Re: 3 Speed To 4 Speed [Re: ScottSmith_Harms] #1359944
12/28/12 07:58 AM
12/28/12 07:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Scott I think Hurst made one.I have a 3 speed that someone stuck in the 65 B sedan I had.It has a Hurst shifter.Seems to be a tight shifter.Been sitting on the garage floor for probally 10 years.Seem no one wants 3 speed trannys.Rocky
Chrysler Firepower
Re: 3 Speed To 4 Speed [Re: 64dodge572] #1359945
12/28/12 12:42 PM
12/28/12 12:42 PM
Fort Worth, TX
Dago Red Offline OP
Dago Red  Offline OP
Fort Worth, TX
Wayne is the 4 speed an improvement, strength wise, or is the 3 speed stout enough?
It seems unusual to me to have a 340 A-body with an 8 3/4 with a 3 speed between the pair.
Re: 3 Speed To 4 Speed [Re: Dago Red] #1359946
12/28/12 12:57 PM
12/28/12 12:57 PM
Nebraska
Dodge-N-Shelby Offline
Nebraska
A few years ago, I picked up a 72 Demon, 340, 3 speed with 3.23s. I swapped in a set of 3.55s and it was a real fun car on the street. 340 was stock, never messed with too. Of course, I didn't have the eqivalent set up with a 4 speed to compare it to either, but it was still a manual!
Re: 3 Speed To 4 Speed [Re: Dodge-N-Shelby] #1359947
12/28/12 01:01 PM
12/28/12 01:01 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
A friend in high school had a brother who owned a 71 Demon with a 340, 3-speed, and 3.91 gears, it was the quickest street package in town! Stoplight to stoplight he couldn't be beat! I thing the combination of the 3-speed gear spacing and the 3.91's was ideal.
JB Rhinehart, Realist
A-Body's RULE!
Re: 3 Speed To 4 Speed [Re: Rhinodart] #1359948
12/28/12 01:25 PM
12/28/12 01:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'll let you know
Re: 3 Speed To 4 Speed [Re: Rhinodart] #1359949
12/28/12 01:27 PM
12/28/12 01:27 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Scott--no, there is no Hurst replacement shifter for the 3-speed available, I am sure there was years ago, but since Hurst was purchased by B & M there is no info available on a part number to go by to possibly find a NOS package somewhere. The 4-speed would be an improvement over the 3-speed, better splits and stronger, although the A230 3-speeds were pretty tough as well.
Wayne
FAX 937-947-4419
Re: 3 Speed To 4 Speed [Re: 64dodge572] #1359950
12/28/12 01:31 PM
12/28/12 01:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea that's what I thought Wayne but figured if one existed you'd know about it. Keep me in mind if you stumble accross anything I can use. I am going to run a Passon 5 speed eventually but I need to get my car put together so while I'm waiting I'm gonna run the 3 speed because that was what originally came in it.
*Have you noticed any differences between the shifter mech/shifter/linkage setups for a /6 3 speed trans and a v8 3 speed trans? Speaking 1970-71 A-body.
Re: 3 Speed To 4 Speed [Re: ScottSmith_Harms] #1359951
12/28/12 01:37 PM
12/28/12 01:37 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Scott--No, its the same crap. Wayne
FAX 937-947-4419
Re: 3 Speed To 4 Speed [Re: 64dodge572] #1359952
12/28/12 01:50 PM
12/28/12 01:50 PM
fresno ca
mikeysmopars Offline
fresno ca
If you do change to the 4 speed The drive line is going to need to be shortened.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 3 Speed To 4 Speed [Re: Rhinodart] #1359953
12/28/12 11:25 PM
12/28/12 11:25 PM
AZ.
696pack Offline
696pack  Offline
AZ.
The three speed has a good gear spread for racing. We sold a new 70 340 Challenger (A66) with that 3 speed and it hauled the mail through the 1/4.
Re: 3 Speed To 4 Speed [Re: mikeysmopars] #1359954
12/28/12 11:28 PM
12/28/12 11:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It shouldn't need shortening with an A body A833. Maybe a different yoke though, depending on the A833 in question.
Don't be the exception.
Re: 3 Speed To 4 Speed [Re: 64dodge572] #1359955
12/29/12 11:04 AM
12/29/12 11:04 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Scott--no, there is no Hurst replacement shifter for the 3-speed available...
Why won't the Hurst Universal 3 speed shifter work?
Re: 3 Speed To 4 Speed [Re: Dago Red] #1359956
12/29/12 12:18 PM
12/29/12 12:18 PM
It was actually pretty common, as the 3-speed didn't get an insurance surcharge like the 4-speed did.
No, I've done this conversion a couple of times; the (all-synchro) three-speed manual trans is the same length as the 4-speed manual, so the driveshaft length is the same. As I recall, you do have to change the front yoke, though, as the 3-speed has a 904 sized/splined output shaft, while almost all 4-speeds have the 727 sized/splined output shaft.
Re: 3 Speed To 4 Speed [Re: Supercuda] #1359957
12/29/12 08:41 PM
12/29/12 08:41 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
It shouldn't need shortening with an A body A833. Maybe a different yoke though, depending on the A833 in question. [/quote
I agree, did the 3 speed to 4 speed swap in a 71 Demon with a 318, all that was needed was a different yoke.
Re: 3 Speed To 4 Speed [Re: Dodgeguy101] #1359958
01/02/13 09:50 AM
01/02/13 09:50 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
While we're discussing 3 and 4-speeds...
Would a 70 E-body 3-speed in a 6-cyl car be the same as the 3-speed in a 340 car? Did they make different 230's in the same year like they did with 833's?
You could get a 383-2bbl with a 230 3-speed, could you not? Between those and 340's thats gotta be a pretty solid transmission.
