Fluiddamper/fuelpumpdrives #1359677
12/27/12 05:42 AM
12/27/12 05:42 AM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Hov do you fit your drives?
I would like to run a cranktrigger,
alternator, Jesel distributor and a beltdriven fuelpump.
I have a Fluddamper on now, a Jesel beltdrive and distributor on the shelf. And a Rons beltdriven pump on the shelf.
Im converting to twin toilets.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Fluiddamper/fuelpumpdrives [Re: fed] #1359678
12/29/12 11:15 AM
12/29/12 11:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Fluiddamper only has a vacuum pump and alternator but you'll get the idea. GZ motor sport provided the arbor and pulleys.
Doug
Re: Fluiddamper/fuelpumpdrives [Re: fed] #1359679
12/29/12 12:18 PM
12/29/12 12:18 PM
AndyF Offline
AndyF  Offline
That shouldn't be too hard to do. I make motor plates that are drilled for the Jesel distributor as well as brackets for the crank trigger and the distributor. Add a Peterson spline drive and you should be all set.
Re: Fluiddamper/fuelpumpdrives [Re: AndyF] #1359680
12/29/12 12:33 PM
12/29/12 12:33 PM
AndyF Offline
AndyF  Offline
What water pump are you planning to use with the belt driven distributor? I've come up with three different solutions, someone else might have some other ideas.
