Re: Cam Experts i have questions
[Re: Plymouth340]
#1359382
12/26/12 04:11 PM
12/26/12 04:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yes more lift. i feel the cam is small for my combo. i did have a 630 lift intake and exhaust and installed this and car picked up a tenth in quarter..got w2 heads that flow about 315 cfm. motor is 398 ci
Your pretty close to max now if your numbers are real... you might get .010 more
[Re: MR_P_BODY]
#1359383
12/26/12 04:15 PM
12/26/12 04:15 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
those numbers are what the cam card said, i havent checked actual lift at the retainer yet
[Re: Plymouth340]
#1359385
12/26/12 04:25 PM
12/26/12 04:25 PM
MR_P_BODY
I would pull 4 sets of springs and use a set of light test springs (each corner) and check what you really have... till then your just guessing and no one can say for fact
[Re: Thumperdart]
#1359386
12/26/12 04:28 PM
12/26/12 04:28 PM
Plymouth340
CEDAR RAPIDS
In addition to what others have said, what do the heads flow and where do they peak at?
i dont have the flow numbers but hensly did a max port job and 2.08 intake valves and this motor pulls hard to 7500 and thats where i"m shifting at.
[Re: MR_P_BODY]
#1359389
12/26/12 04:48 PM
12/26/12 04:48 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
If you are trying to cut it as close as possible - dont skimp and check one cylinder - check all 4 corners and make sure you have the room - unless you have a completely blueprinted engine now with the deck heights at all corners, etc - dont take that chance.
[Re: Locomotion]
#1359392
12/26/12 07:18 PM
12/26/12 07:18 PM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
There are so many variables I think its almost impossible to tell. For example - you can go with a faster ramp cam at the same rated duration and actually have more duration at .050 and .200 lift. This may get you in trouble with V to P clearance. Also can open lobe seperation to increase V to P. Advance and Retard is another factor. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: AndyF]
#1359393
12/26/12 11:35 PM
12/26/12 11:35 PM
Plymouth340
CEDAR RAPIDS
If it is a roller cam then you should be able to add more lift without any problem. On a flat tappet cam you might be getting close to the limit.
Best way to know for sure is to pull the valve springs off of one cylinder and then map the valve to piston clearance over a range of 30 or 40 degrees of crank movement. Once you have that information you can talk to a cam grinder and tell them what you have. Then it is just a matter of figuring out how much area under the curve they can fit in there.
yes solid roller
[Re: Locomotion]
#1359394
12/26/12 11:37 PM
12/26/12 11:37 PM
Plymouth340
CEDAR RAPIDS
If you change anything with the cam or rockers, you really should re-check piston-to-valve clearance instead of taking anything for granted. Besides the obvious higher lift with higher ratio rockers or bigger cam lobes, duration, lobe seperation and where it's installed will affect the clearances as well.
checking the piston to valve is a must..
