oil pans for strokers??? #1358378
12/24/12 09:16 AM
12/24/12 09:16 AM
canada
jp15 Offline OP
jp15  Offline OP
canada
anyone know of a quality race oil pan that doesn't have to be mutilated to fit a 4.25 stroke small block (340 mains)
Thanks for any info., Merry Christmas
Jim.
Re: oil pans for strokers??? [Re: jp15] #1358379
12/24/12 09:20 AM
12/24/12 09:20 AM
gregsdart Offline
gregsdart  Offline
I went with a custom pan years ago and even at $550 it was worth every cent. I have four old ones (for BBs) in my storage shed. If you plan on going faster and faster, now is the time to get the best pan you can!
Re: oil pans for strokers??? [Re: jp15] #1358380
12/24/12 11:43 AM
12/24/12 11:43 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Jim.
Emailed Charlie's back in the summer regarding what was needed for a new oil pan with kickouts, notches, tray, etc., and he nailed it spot on. He kept his promised lead time too!
Re: oil pans for strokers??? [Re: LSP] #1358381
12/25/12 03:22 AM
12/25/12 03:22 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My kevco cleared my 4.25 crank without too much work but clearing my hooker headers was another story. Lots of work and cussing
Re: oil pans for strokers??? [Re: DavidDean] #1358382
12/25/12 01:20 PM
12/25/12 01:20 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
What rod journal is the crank? And is it a caps crew rod? A 2" journal 4.25 doesn't poke out very much more from the crank center than a 4" with standard mopar width journals.
WIZE
In Car:
Re: oil pans for strokers??? [Re: DavidDean] #1358383
12/25/12 02:17 PM
12/25/12 02:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Which Kevco pan did you go with David? I was looking at their rear sump pans (M405) as I don't have a stock K any longer either.
Re: oil pans for strokers??? [Re: Streetwize] #1358384
12/25/12 05:41 PM
12/25/12 05:41 PM
canada
jp15 Offline OP
jp15  Offline OP
canada
have not purchased the crank yet (it will be 2" journal) just chasing down the possible glitches before I start collecting pieces.
Jim,
Re: oil pans for strokers??? [Re: jp15] #1358385
12/25/12 08:14 PM
12/25/12 08:14 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have the M-201pp pan. I use the BPE crank it has the 2" journals. It uses a comp star rod that has a short cap screw. I did have to peen the windage tray slightly and I informed kevco of the stroke
