Re: 440 source roller rockers
[Re: 493_DART]
#1357066
12/25/12 03:53 AM
12/25/12 03:53 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
If you cant quite afford the Harlands...the next step would be Dove or Hughes . I ran used Doves for several years with now problem and I "think" they still make them in Ohio ?
Either one is around $425 last time I looked.
I agree..those are all decent depending on the application. Rockers are not a place to go cheap.....only exception is ISKY or Crane ductile iron rockers for non-roller cam applications are a cheaper but decent option. I bought a brand new set in the box of old (from the 80's) crane ducticle rockers for like $100 a few years ago on ebay. They are just fine for my solid cam under .600 lift. Even came with the original receipt...lol.
[Re: buck440]
#1357069
12/26/12 12:06 AM
12/26/12 12:06 AM
Posts: 75 North Carolina
Mopar dragster
North Carolina
I LOVE the Crane Gold race rockers. I still have three brand new kits on the shelves waiting for their turn in the sun. I haven't been able to tear them up.
Please see my brother Darrell Kiger at Wyo Racing and Rods for all of your drag car fabrication and restoration needs. From Pro Mod to concours restorations, he is the man. (336)463-4309.
[Re: Dean_Kuzluzski]
#1357073
12/26/12 08:01 AM
12/26/12 08:01 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Soooooo, I just got some Harland Sharps from Mancini Racing. These are the "Exclusive" ones, supposedly, only available from them. They advertise them as a "bushed type" but there's NO bushing just a "non-roller" set-up.
That's just plain deceptive then, thanks for the heads up.
I was considering buying a set for my big block but will pass now.
How can you use the term "bushed type" without a bushing being present?
#1357077
12/26/12 12:11 PM
12/26/12 12:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They should have stated something like "shaft type non-bushed" to be perfectly clear. Yes, it is a bit decepetive but at that price range I haven't found any others that are bushed. Or state that they are.
I tend to look at it like this............the non-bushed type may actually have more "loadbearing" ability than the bushed rockers that use two narrow bushings like the Comp Cams rockers I've seen. Roller fulcrum rockers are actually harder on the shafts due to the needlebearings having a finer load specifically focused where each needlebearing touches than the way a bushing spreads it out. That's when the loose tolerances of poor manufacturing and poor metal quality breaks down those import rockers so quickly. AND the stock set-up never had bushings due to the system having a direct oil fed system pushing oil on them. They don't usually gall until dirt or metal is in the motor.
So, you either pay the big $$ and get HS, T&D or Jesel.........or mid-to low end hobby guys like myself buy the non-roller extruded Hughes, Dove or budget HS's.
The Doves do look like a nice product and American made!!
http://www.4secondsflat.com/Dove%20Rocker%20Arms.htm
There is a reason that the roller rockers use the bearings... its to get oil to the shaft area... if you run a bushed style rocker with big spring pressure it doesnt get oil on the shaft.. yes it will get oil on it at low RPM... thats why they say dont use them on high RPM engines(it doesnt have time to get the oil to slide back down to the bottom load area)
Re: 440 source roller rockers *DELETED*
[Re: buck440]
#1357079
12/26/12 03:32 PM
12/26/12 03:32 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: VernMotor]
#1357083
12/27/12 01:19 AM
12/27/12 01:19 AM
Quicksilver440
Central Valley, CA.
I have seen a lot of post about Indy rockers ..being Bad..I only run a .590 lift cam with 325 open pressures and have run crane iron rockers for years I have 2-3 of them galling. on the inside. I have good shafts. it cleans right off the shafts .but I need to do something. I wish I could have then bushed. But not sure it is worth the money to do. or who to get to do it. I don't think R.A.S is doing anything.
I'd love to have my ductiles bushed too if it isn't too expensive.
