Page 1 of 3 1 2 3
header kit or parts #1356909
12/22/12 01:38 AM
12/22/12 01:38 AM
nc
E
earthmover Offline OP
E
nc
2 step style
1st pri dia... 2.050" ... length .. 16.7" to 18.3"
2nd pri dia... 2.175" ... length .. 16.7" to 18.3" coll. size 3.725" to 3.975" .. length 17.9"
this is the header I plan to build for my race car .. what are you guys doing for the bends and flanges??? buying kits and make them work how you like or just buy a lot of diff. bends and so on???who has the best price on this kinda stuff??? I have seen where guys buy big block chevy kits and use them with the mopar flange cut weld cut weld..lol
Re: header kit or parts [Re: earthmover] #1356910
12/22/12 02:27 AM
12/22/12 02:27 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i bought Hooker Flanges & collectors off Summit & then bought bends from a local muffler shop. fabricated everything up with taped joints til i was sure & tacked them with the mig. then i could remove them, weld them up nice, grind back my welds so they looked pretty under a nice header coating. i know mine aren't equal length but it sure is easy to work on & around.
with the Hooker flanges n collectors came a pair of their embossed logo's which i tacked on. it sure messes with the heads of the newbies who think you can buy pipes like this from the manufacturer.
Re: header kit or parts [Re: earthmover] #1356911
12/22/12 03:19 AM
12/22/12 03:19 AM
Hedmans race plant is in either N.C. or S.C., they offer kits of bends of both sizes you need and they also offer either flange kits with welded stubs or plain precut flanges Summit also sells bend kits, check around for what you need. I ended up buying all the parts from Hedman through Summit to do two different cars, one with 2 inch kit and a 2 1/8 kit to make them step to a 3.5 inch collectors and the other is from 2 1/8 to 2 1/4 primarys into a 4 inch collector with welded 2 1/8 stubs I had Summit have Hedman drop ship all the the part to me direct Not cheap though, shop around first
Re: header kit or parts [Re: Cab_Burge] #1356912
12/22/12 08:19 AM
12/22/12 08:19 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
Columbia river mandrel bends usually has the lowest prices.They offer flanges for mopars also.I order a few things from them.Quality is good as well.
Re: header kit or parts [Re: Moparpoor] #1356913
12/22/12 09:12 AM
12/22/12 09:12 AM
nc
E
E
nc
thanks guys.. cab I didn't know that I will have to check that out as well..
Re: header kit or parts [Re: earthmover] #1356914
12/22/12 10:46 AM
12/22/12 10:46 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Doing a set on a 71 dart chassis car with a 655 indy motor now. I get 90% of my header parts from link below. Goodluck
http://www.mandrel-bends.com/catalog/
One day I will have something cool here.
Re: header kit or parts [Re: sdaurity] #1356915
12/22/12 04:06 PM
12/22/12 04:06 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
BGR makes a nice set of headers in house
5.53 @ 125 1/8th on the launch control..more left in her!
Re: header kit or parts [Re: Eric] #1356916
12/22/12 04:48 PM
12/22/12 04:48 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Since we're talking about building headers, where can I get that star shaped filler piece that fills in the space between the primary pipes before the collector is put on? I don't know what that piece is called, so its hard to find it online.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: header kit or parts [Re: earthmover] #1356917
12/22/12 05:37 PM
12/22/12 05:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks for posting this subject because I am doing a fenderwell exit for my 69 satellite with victor heads in a 2.25x32 4" collector pipes.headman had the flange/stub,edelbrock collector looking on summit site.
Re: header kit or parts [Re: Clanton] #1356918
12/22/12 06:58 PM
12/22/12 06:58 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
I did a set of fenderwell headers on a 68 runner used a set of jegs 2" chassis header kit.The kit was less than 200 had to add a few bends and mopar flanges.They were less than 400 in materials totally finished with out coating.
Re: header kit or parts [Re: DusterDave] #1356919
12/22/12 08:02 PM
12/22/12 08:02 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
that star piece was part of my Hooker collector, the tubes slid in til they bottomed out on the back of that merge point.
Re: header kit or parts [Re: DusterDave] #1356920
12/22/12 08:23 PM
12/22/12 08:23 PM
Renton Washington
Triple Threat Offline
Renton Washington
http://www.coneeng.com/collector_components.html
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: header kit or parts [Re: Triple Threat] #1356921
12/22/12 09:16 PM
12/22/12 09:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
This stuff is expensive but it is the best NASCAR uses their stuff http://www.burnsstainless.com/
Gus
64 Plymouth Savoy
Dana 60
Re: header kit or parts [Re: fourgearsavoy] #1356922
12/23/12 12:00 AM
12/23/12 12:00 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I priced all the parts for mine as coming to 700$ with having extra pipe left.200$flange,200$ for the collector,300 for tubing.
Re: header kit or parts [Re: Clanton] #1356923
12/23/12 12:46 AM
12/23/12 12:46 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Check Stahl for header kits.
I got my tubes and collectors from them and bought the W-9 flanges from SPD.
They sell theirs in varying stages of completion and make a nice part IMO.
As for the star , I liked Headers By Ed 's approach.
He heats the tubes where they transition into the collector and pulls the inside of the tubes in with a needle nose vise grip , so where the four tubes come together get the appearance of a cross. He claimed this was worth 5 h.p. on the dyno as I recall.
Re: header kit or parts [Re: tubtar] #1356924
12/23/12 04:34 AM
12/23/12 04:34 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Ed has a good audio tape on header building.
Re: header kit or parts [Re: Clanton] #1356925
12/23/12 08:30 AM
12/23/12 08:30 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
I priced out the stuff I used.Jegs 21/4 chassis header kit 555-31886 $130 They also come with 4"collectors
Columbia River flanges and box of tubing and bends
hf-ms38-bbm-200 3/8 flanges $30 each you can due 1/2 flanges for 10 more dollars I believe
ubk-16-225-300-ms large box of bends and some straight $112
The box of bends and tubing was overkill.Just wanted to make sure to have enough.It did come in handy done the road for other projects.
When I built a set we used 2" and was already started.You may even be able to do a set with out the extra bends.It sure made it easy with them though. You are looking around $300 to do a set in mild steel.
Hope that helps!
Re: header kit or parts [Re: Moparpoor] #1356926
12/23/12 09:40 AM
12/23/12 09:40 AM
nc
E
E
nc
thanks guys keep it coming.. any more pics ???/ chassis headers is what I am after but all is welcome to give me a good idea of how and what to do...
Re: header kit or parts [Re: Moparpoor] #1356927
12/23/12 04:38 PM
12/23/12 04:38 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Hope that helps!
I bought the Jegs 2 1/4" kit for a big block chevy. All I need now are the D-port Hemi flanges. Found them for a $100. I don't like the Jeg's collectors and will use a merge.
Re: header kit or parts [Re: 52savoy] #1356928
12/23/12 05:11 PM
12/23/12 05:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am going with a slipon collector,Dynatech 783-81245 2 3/8 to go over the 2 1/4 pri tube[80$ ea.]OR a hedman 14146 2 3/8 x 4 1/2=209$for both.
Page 1 of 3 1 2 3
