Re: bronze dist drive gear
[Re: dynamite]
#1356797
12/21/12 09:15 PM
12/21/12 09:15 PM
Posts: 4,799 ILL
MLR426
ILL
Did you put in a new bronze distributor shaft bushing in the block when the engine was built ? A worn bushing is a major contributor to premature wear on the gear. Their is a new harder bronze gear available and I believe I got it from Milodon ?, from what I was hearing a few years ago the manufacturer that Mopar was using made a run with softer than normal bronze which did cause permature wear supposely. I've heard a few stories but other things need checked also, block bushing, gear meshing depth etc. I've ran mine for years in my hemi AAR cuda pro street car and before that it was in the race hemi I used on the drag strip for many laps with big valve springs etc. Are you using a cam button also ??
MLR426
