Big Block Head Flow
#13565
12/08/04 04:25 PM
12/08/04 04:25 PM
Posts: 1,143 Imlay City, MI
DTT
super gas
super gas
Imlay City, MI
I am working on some testing using some big block heads. The castings I am using is a 906. I am using a SuperFlow 600, and 25" H2O. I started out with a stock flow of about 172 IN and 142 EX. Modifications I have done, testing after each one include 3 angle grind, 5 angle Serdi grind, polished the chamber and blended the seat area, then worked on the bowl and short side radius using the porting tempates. I then flowed it with backcut valves After all of that I was expecting a decent amount of CFM. The final Numbers were 181.5 IN and 156.5 EX. I did pick some low lift flow numbers. I would like to achieve arounnd 230 CFM of flow to achieve 500 Horse. What am I doing wrong, Let me know if you need any more info and or numbers. Thanks!
1978 Pro Street D100
1936 Dodge truck (Hot rod)
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
1995 Jeep Grand Cherokee
1971 Big Block Demon (Dads)
Re: Big Block Head Flow
[Re: DTT]
#13566
12/08/04 04:49 PM
12/08/04 04:49 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
a couple of things...First, it seems most of the porters here test at lower vaccum, but convert the findings to 28" specs...This may be while you're a little lower than what is read here. Second, what type of valves are you testing? For lower lift flow, you should be using nail head performance style, not the stock tulip type. Also, many times when you do work in the bowls, the guide area and pushrod pinch should also be touched a little, otherwise it's a choke point. You may want to post in the race forum..See if Curtis or Dwayne can shed light here.
[Re: DTT]
#13567
12/08/04 05:34 PM
12/08/04 05:34 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
its really difficult to try and compare flow from one bench to another.
basically, you need to test somekind of heads thats a known quantity on that bench to get a baseline.
the 172 you're getting from the stock intake port would only be 182 @ 28", which is still way below(by about 30cfm) the norm.
what size bore adapter are you testing on?
what are you using for a port entry radius?
[Re: fast68plymouth]
#13568
12/08/04 05:45 PM
12/08/04 05:45 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
go to mopar muscles's website. there's a 3 or 5 part series on BB head flow done by steve dulcich, with a lot of good info. IIRC, he achied close to 230cfm of flow using the MP porting templates.
[Re: DTT]
#13569
12/08/04 08:20 PM
12/08/04 08:20 PM
Posts: 1,361 Wild West
M_D
Wild West
What lift were those flow numbers achieved at? Have you checked to be sure you operated and read the bench correctly? Have you tested more than one set of ports?
[Re: M_D]
#13570
12/10/04 01:54 PM
12/10/04 01:54 PM
DTT
super gas
super gas
Imlay City, MI
I believe that the main problems I had with the flow numbers is that th bore adapter i use is actually somewhat small. The valves open completley, but I feel there is some shrouding going on. Another concern is getting the head exactly centered. I am not using dowels t oensure exact location. I am sure of the bench calibration. I am using a 600 with Flow Com. So basically you cant mess it up there. My leakages werent real bad (about 2CFM) I read the article on Mopar Muscles site. It is good and very helpful. I perfomed a back cut on the valve and really picked up some flow, with a minor mod like that. I am going to finish my bowl work and possibly enlarge the valves, the build my own adapter and do some more testing. Thanks for all your help.
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#13571
12/10/04 01:56 PM
12/10/04 01:56 PM
DTT
super gas
super gas
Imlay City, MI
Also I have heard some conflicting info on the short side radius of these heads. Should you leave it alone or smooth its transition out? What about snad blasting an intake port after your port work? I have been told this gets the right texture for a good atomization. Is this true? Thanks
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#13572
12/10/04 08:03 PM
12/10/04 08:03 PM
fast68plymouth
So. Burlington, Vt.
i'd test on a 4.250 bore minimum.
if you use that size, its best to shift the head so the side of the chamber your testing(intake valve or exhaust valve)is adjacent to the wall of the bore adapter.
you didnt say whether or not you were using a radiused port entry. this is a must.
if you're looking for "the big number", intake short turn work is absolutely mandatory.
its a "make or break" part of the job.
done correctly the head will come alive at high lifts....done incorrectly, the port will die at .450-.500 lift(on a 906 head).
#13573
12/10/04 10:18 PM
12/10/04 10:18 PM
DTT
super gas
super gas
Imlay City, MI
I am not using a inlet radius. Will this affect numbers much? Also what should I avoid on the short side radius? Also will I see any major gains using the larger valves? I do not have hardened seats either, should I use these? The engine will not be drove a whole lot, just on weekends and some nice day drives Thanks
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#13574
12/11/04 09:43 AM
12/11/04 09:43 AM
Without a radiused entry to the port the air with not enter smoothly and it will break up. You can tell the difference in sound with and without a radius.My bench is home made.I've had very little time to mess with it since I got it built due to work but I got today off and I think I'll fool around with it.I've been trying to figure out a good baseline in which to test my heads.I think what I'm going to do is drill a nice size hole for an orifice plate. One that I know will flow a good bit more than a stock 906 intake port but not way more than.Then I'm going to just figure that the port flows about 210cfm at .500 lift. This may be a bit conservative but I would rather be conservative than to think my heads are going to flow like B1's. From there I'm going to read the percentage scale and whatever it reads I will assume that to be 210 cfm of whatever the orifice plate is. Then I'll be able to exact a figure for the maximum cfm for the orifice plate.I'll do all this at 28 inches of water.
#13575
12/11/04 09:58 AM
12/11/04 09:58 AM
I would also like to add something about the orifice plates. Once I give one plate a cfm figure I should be able to guage other orifice sizes by flowing them against it.That way I can flow ports to the nearest sized orifice plate that flows slightly higher than the port.That way I can get closer to 100% and be more accurate than if I used an orifice plate that outflows the port considerably higher.
#13577
12/11/04 01:00 PM
12/11/04 01:00 PM
DTT
super gas
super gas
Imlay City, MI
I have done much research and testing on the flowbench. Have you ever tested a newer style stock production head? I have flowed many without an inlet radius, and I have also flowed them with them on. I know that when comparing numbers to other benches, a radius inlet must be used. I also understand that the guid e can allow for much more CFM. I would like to see what I get without the radius and then compare it with the guide, and see how much CFM it makes a difference of. Also flowing on 28" compared to 25". I know there is CFM here as well. Thanks
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#13578
12/11/04 02:04 PM
12/11/04 02:04 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You MUST use some sort of radiused entry!!!! You see if the air goes turbuelent as it enters the port, then any data collected is no good! It must enter the port smoothly, and yes the numbers will go up becuase the turbulence is gone. This is a must, not to get false high numbers but to get CORRECT numbers! I use clay, and stick to a shape on every head so that helps to keep all tests evenly comparable. Brian
Brian Hafliger
[Re: DTT]
#13579
12/11/04 02:16 PM
12/11/04 02:16 PM
fast68plymouth
So. Burlington, Vt.
IMO, if you're not using a radius entry, the numbers are meaningless.
the jist of your original post is, why are the numbers on your 906 head so low?
the answer is the test procedure is being done incorrectly.
#13580
12/11/04 03:20 PM
12/11/04 03:20 PM
DTT
super gas
super gas
Imlay City, MI
For before and after comparison I do not think that the radius inlet is needed. However yes, my post asks why it is low compared to other findings. In that case I do feel that is essential for bench to bench data comparison. So I can see your point. Thanks a lot guys.
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#13581
12/11/04 04:59 PM
12/11/04 04:59 PM
fast68plymouth
So. Burlington, Vt.
i disagree.
i think if you did a series of tests using a radius entry, and not using a radius entry, for the various stages of port modification, you'd find that things that were worth fairly substantial gains with the radius entry showed very little gain without it.
flow testing the head without the radius entry on the intake gives an incorrect shape to the flow curve....especially in how it relates to the exhaust port. the better the port is, and the higher its capacity, the more important the radius entry becomes.
read the operators manual ....it clearly says to use some sort of radius air entry.
#13582
12/11/04 05:55 PM
12/11/04 05:55 PM
M_D
Wild West
I agree with Fast68. A radius inlet will affect some ports more than others due to various factors, but one point is the better the port flows for the cross section, the more likely tests will show it with a radiused entry incorporated. In other words, a radius inlet will allow you to acurately see any actual improvements. That's because as the velocity gets higher (more flow for a given cross section), the turbulence gets more pronounced at the sharp inlet. When a port is kind of “lazy”, the velocity along the port walls can be pretty low. But as the flow increases, much of the additional flow will be closer to the port walls.
Most successful porting increases the flow while keeping the cross section increase minimal.
[Re: M_D]
#13583
12/11/04 06:25 PM
12/11/04 06:25 PM
DTT
super gas
super gas
Imlay City, MI
I am doing all of this research at a State University where the instructor is a reputable guide, and teacher. He has sat in with Joe Mondello and has been doing flow testing for a very long time. He is my operators manual. I have searched in my 200 page lecture note book, and it specifically says: "On the intake side, a radius guide should be used.(especially when comparing to other machines), If however you are only doing before and after comparisons, it is not needed." I respect your opinion, and do not want to make anyone angry, because I have been helped on this post as well as many others. I am just stating what I have been taught. Thanks
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#13584
12/11/04 06:46 PM
12/11/04 06:46 PM
Quicktree
sounds like you need a new teacher
[Re: DTT]
#13586
12/12/04 09:40 AM
12/12/04 09:40 AM
I know a Physics professor that ran a car out of oil .... twice. I have two advanced science degrees, however, Experience has been my best professor.
[Re: DTT]
#13587
12/12/04 08:25 PM
12/12/04 08:25 PM
DT,
Not to offend you, your teacher or Joe Mondello, .. who I spoke to yesterday, ..
I have been doing Pro stock, top sportsman, Comp elm, etc heads for 25 years, .. set MANY national records, .. these guys are telling you the truth, .. you MUST use an inlet guide to allow the air to enter the port properly. No Question.
Curtis
[Re: DTT]
#13588
12/13/04 04:09 AM
12/13/04 04:09 AM
DTT,
No, Don't let Him Know! Take in what he has to say, ask others, then figure out what is right. Experience is what you need. Take in what all people tell you and in the real world (trail and error) you'll figure out what is right and what is wrong! Teachers are paid by our Tax Dollars, some want to teach you to be a better person, some want to get their check and then you have there union. So learn to use your brain (Think!) and to read all books and information, and most of all, pay attention to the older experienced people. They Know! They've Been There, Done That!
#13589
12/13/04 12:29 PM
12/13/04 12:29 PM
DTT, If cylinder heads is REALY what you want to work with, .. to earn a real living doing it you must understand fluid dynamics. You need to be an engineer to go much past the basic porting. You need to understand and use flow coefficients, area ratios,. etc. The difference in todays job market place for a cylinder head guy is his/her education. If you have a fluid dynamics degree, .. and can program G code to run a CNC machine you'll get a good job. Otherwise you'll be stuck. If on the other hand you see your self as a pro shop, like Chapman, CFE, etc. then it's even MORE important to know fluid dynamics engineering and how to use it in cylinder heads. Shops like these do engineering for the manufacturers. This discussion of testing with an air strainer would not even be a question with some basic fluid dynamics study. here's a link to a few good books, .. http://www.amazon.com/exec/obidos/tg/detail/-/3540416072/qid=1102954130/sr=1-5/ref=sr_1_5/104-4469133-4034347?v=glance&s=bookshttp://www.amazon.com/exec/obidos/tg/detail/-/0198596790/qid=1102954130/sr=1-9/ref=sr_1_9/104-4469133-4034347?v=glance&s=booksDo more searches on amazon for fluid dynamics books, .. and cylinder head books. Read the vast amount of material available from SAE. http://www.sae.org/Don't go bust on your teacher, .. take duster's advice, .. learn what you can from him but understand he's only one source. Curtis
[Re: RyanJ]
#13591
12/13/04 01:33 PM
12/13/04 01:33 PM
Ryan, I'll leave the S plug out if the customer is standing there, .. get's a real nice flow number, .. Hey did you got to PRI ???????????????? I had my cell phone, .. thought SOMEBODY from here would call, .. . .. Curtis
[Re: TS3303]
#13593
12/15/04 03:23 AM
12/15/04 03:23 AM
Jim,
I had posted my phone # here some place, .. or I thought I did, .. yea, .. I would have liked to meet you.
I spent a bunch of time looking at CnC stuff, .. hangin at Sonny's booth with his CnC guy, long time friend, .. and of course over at Indy hangin with Ken & Herb.
Curtis
