NHRA rules for 10 O and higher #1356143
12/20/12 02:43 AM
12/20/12 02:43 AM
St. Louis, MO
mopardamo Offline OP
St. Louis, MO
I thought that NHRA required a roll bar and the drivers door bar for cars down to 10.000. Is this correct for 2013?
Damon
Re: NHRA rules for 10 O and higher [Re: mopardamo] #1356144
12/20/12 02:47 AM
12/20/12 02:47 AM
Renton Washington
Triple Threat Offline
Renton Washington
Correct, unless the car has fiberglass doors, which then you need a Roll cage and a window net.
If the car is 2008 and newer, and unmodified, you need nothing til 9.99 or 135
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: NHRA rules for 10 O and higher [Re: Triple Threat] #1356145
12/20/12 04:41 AM
12/20/12 04:41 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It was with a stock firewall from 11.49 to 10.0 a minimum of a 5 point bar I think and I think it still is. Which means you dont have to have the pass side door bar. The main hoop the 2 rear bars and the drivers door bar is the least you can do but I have never seen anyone put a bar in and not do the pass bar. I dont think you have to have the 2 bars from just below the center bar of the main hoop to the trans tunnel or at least it was optional when I put my 6 point bar in. Ron
