Re: exhaust gurus, staggered mufflers?
[Re: fullmetaljacket]
#1355235
12/18/12 09:46 PM
12/18/12 09:46 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The placement of the X pipe is important. What happens beyond it is much less so. I wouldnt worry about it.
#1355236
12/18/12 10:03 PM
12/18/12 10:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is there a problem with one of the mufflers being a little down or up stream in the system by a few inches that it could present a flow problem? I'm thinking for fitment issues that one of my mufflers (Passenger side) would be placed about 4-5 inches closer to the engine than the drivers side. Is there an issue with the balance of the exhaust note, flow being that I have an X-pipe in the middle of it all?
Well most cars (older cars with the muffs under the back seat) are already staggered due to the pass side cyl head being back farther BUT when using a X pipe you want the X to be 1/2 the distance from the end of the primaries to the front wall of the muffs... is it gonna kill you if it isnt... no and I cant say for fact how much it might hurt... but I will tell you that packaging is more important than a 1 or 2 hp loss
#1355238
12/19/12 12:40 AM
12/19/12 12:40 AM
MR_P_BODY
In "end of the primaries, you mean the primary tubes of the headers where they converge into the collector, not the very end of the header collector. Am I correct?
You are correct
