Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1354226
06/11/14 11:27 PM
06/11/14 11:27 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Which set of these shims/nuts do you think will get the boot? On one side for the fender aprons, an ounce was shaved with the aluminum versions. On the passenger side, a whopping 2-3/4 ounces were removed being that there were five steel shims to seat and align that fender correctly. Fairly easy to make using flat stock aluminum and cutting/filing a U-shape slot for the fastener.
Better yet, is plastic shims that can be bought at HD as flat stock. Just drill through a stack and use what you need. Half the weight of the aluminum and easier to work with.
It can even be U shaped slotted fast with a drill bit or die grinder.
I posted this before, somewhere in the thousand or so posts on this thread.
[Re: hemi-itis]
#1354228
06/11/14 11:56 PM
06/11/14 11:56 PM
fullmetaljacket
[Re: Sport440]
#1354229
06/12/14 04:49 AM
06/12/14 04:49 AM
fullmetaljacket
(Better yet, is plastic shims that can be bought at HD as flat stock. Just drill through a stack and use what you need. Half the weight of the aluminum and easier to work with.
I posted this before, somewhere in the thousand or so posts on this thread.) Sport440: I should of thought of that one. Though the aluminum types are super light, the plastic versions would be lighter being that we are talking about micro ounces here that at the end of the day could add up. Thanks.
#1354230
06/14/14 01:31 AM
06/14/14 01:31 AM
fullmetaljacket
(14) Trans oil pan bolts saved almost 4.5 ounces. The engine oil pan bolts saved an additional 5.5 ounces. In English, that translates to almost 1/2 pound. I used 2024-T4 bolts with aluminum lock washers. By the way, that Moroso fabricated aluminum pan saved 4 pounds from the cast aluminum pan I had before.
#1354234
06/14/14 10:47 PM
06/14/14 10:47 PM
Posts: 4,669 Wichita
GY3
Wichita
The old Mopar chrome one might create more heat in the fluid than its worth. I'd rather stay with an old and true deep regular steel one if the budget is tight. The steel one is I believe lighter than the cast aluminum types.
The 518 pans are deeper and bolt right up. That's what I use on my 727's.
Very tough black finish (powdercoat?).
[Re: RMCHRGR]
#1354238
06/15/14 10:30 AM
06/15/14 10:30 AM
fullmetaljacket
Safety and peace of mind is found in Titanium, though at a price. Steel is the overall champ in safety, but it only needs to be applied to certain critical places. Case in point, some of my buddies have mentioned why not use aluminum bolts for the pulleys,oil pump mount and such. I said, that was not logistical and from a engineering stand point, quite unrealistic and unsafe. I'm not an engineering expert or even a metallurgist, but I do understand real stresses and centrifugal forces that do things to things over time. Certain items should be left alone and others can be fiddled with.
The fenders hang with good grade aluminum hardware because of the vibrations and oxidation, but in some cases, you can get away with certain fasteners because there are multiples of that fastener holding the item like the pan.
I've got to flic my Radiator and trans cooler which is just as big as the Radiator itself, but the same as yours, aluminum hardware and brackets everywhere.
#1354239
06/16/14 05:41 PM
06/16/14 05:41 PM
fullmetaljacket
Here's a whole combo of front end stuff that's been tricked, but notice the over size Hatten trans cooler and brackets. The bumper and valance have spent lots of time at the Gym as well.
#1354243
06/19/14 12:50 AM
06/19/14 12:50 AM
fullmetaljacket
Since when ever the rear quarter windows are fixed closed, the tracks and whiskers hang there for the ride. Removing a good portion of both the tracks bottom ends as you see here shaves an additional 1-1/2 pounds. After that, a small aluminum brace is all that's needed to keep the track from shaking around in there.
#1354245
06/19/14 01:08 AM
06/19/14 01:08 AM
fullmetaljacket
This particular piece will instigate the creative side of me as it will turn up in a light weight alloy very soon. Keep posted as I walk you'll through the process. You won't believe how I will forge the various concave and swaged shapes of the horn ring and center dome. Some times there are things in house hold catalogs, hardware stores and other sections of automotive items that lend themselves nicely to your projects. The center faceplate with the CORONET title will have to have the letters laser cut by a good friend in the metal business.
