Page 37 of 179 1 2 35 36 37 38 39 178 179
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353906
05/30/13 02:52 AM
05/30/13 02:52 AM
fullmetaljacket Offline
Another image. I'm going to call them my own. "2nd Wind mufflers".
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353907
05/30/13 02:55 AM
05/30/13 02:55 AM
A bellies view.
Chris can weld his A$& off. He also probably thinks I'm cooked. Actually, he has made many an exhaust from the material.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353908
05/30/13 01:09 PM
05/30/13 01:09 PM
Dyno1 Offline
Dyno1  Offline
I may have missed it, but does anyone make front aluminum bumper brackets for the 67-69 Barracuda?
Re: Real world weight loss program and it` cost.......... [Re: Dyno1] #1353909
05/30/13 01:14 PM
05/30/13 01:14 PM
Some people have including myself. Though easy looking to the naked eye, very critical bending and shaping is the norm so that the Bumpers mount on like factory. I would not do them again. Too much work for the almost non existent profit. Maybe some one here will come in a offer.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353910
05/30/13 07:45 PM
05/30/13 07:45 PM
Here's an easy stealthy way to get 1-1/4 pounds off high and front of the car more or less. The Glove box door weighed 3 pounds stock and then after I gave it a shave, it weighed 1-3/4 of a pound.
The door still works and locks as if stock. Once closed, it all goes away to the eye.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353911
05/30/13 07:49 PM
05/30/13 07:49 PM
When in need of vital sign equipment, opt for the lighter Ultra-lite gauges from Autometer. Even the 5" Tach was about a 1/2 pound leaner.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353912
06/14/13 04:24 PM
06/14/13 04:24 PM
So here it is, the long awaited aluminum exhaust ready to be introduced to the car. At 3.5 ID, it will flow good to the special mufflers. Chris over at Unobtanium made them from scratch using my drawings of a Dyno-max Ultra-flo straight-thru Muffler.
The system will have to be mounted using special rubber mounts at various points to keep it from cracking. It will weigh 22 Lbs complete with the 45 degree down turn tails added in to exit before the rear end.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353913
06/14/13 04:25 PM
06/14/13 04:25 PM
Tunnel emission.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353914
06/14/13 04:33 PM
06/14/13 04:33 PM
State of confusion
Thumperdart Offline OP
State of confusion
Lookin good man and this is definately something I`ll focus on in the future..........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353915
06/14/13 04:57 PM
06/14/13 04:57 PM
I'll have to let you'll know how it hangs and fairs in this rough street climate. I have to burn the Midnight oil and my Brains on how to install it correctly and safe. A long way from the original 70 Lbs of the system way back in the day.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353916
06/14/13 05:06 PM
06/14/13 05:06 PM
State of confusion
State of confusion
That`s a big concern for sure because if it`s not durable then of course I`ll look somewhere else for more weight savings........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353917
06/17/13 11:41 AM
06/17/13 11:41 AM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
I added kirkey seats and made rear seat a foam replica and got the car down to 3390 from 3510 with me in it, 3137 alone. Pretty good as it started at 3700 and with losses from alum heads, hood misc brackets its coming down to a manageable level.
Re: Real world weight loss program and it` cost.......... [Re: tsanchez] #1353918
06/17/13 12:35 PM
06/17/13 12:35 PM
State of confusion
State of confusion
Good ideas and great wt. savings right there.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353919
06/17/13 01:12 PM
06/17/13 01:12 PM
Light is might and Lean is mean.
Will the real Weightwatchers step forward please. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353920
06/29/13 07:29 PM
06/29/13 07:29 PM
Saved 3-1/2 pounds with the new light weight Aluminum copper coated Accel battery cable. Battery was weak, so I'll reply with real results once I take it for a test run. Cranking is the same as before.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353921
07/08/13 11:11 PM
07/08/13 11:11 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Lee, unreal how you always are thinking out of the box. Incredible idea, and brilliant work. I'm sure your drawings will go up on the auction block someday. Anyway to make 3.5" oval exhaust?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Real world weight loss program and it` cost.......... [Re: sunroofgtx] #1353922
07/08/13 11:33 PM
07/08/13 11:33 PM
Rick.
I know that they make light weight wafer thin oval in stainless from a company in California by the name of "Burns stainless", but I do not know if it comes in Aluminum. Burns Stainless is where I got some of my mandrel bend 45% tubes and reducer tubes.
I made the X-pipe in my new system from scratch using 45% mandrel bent sections that I got from my local Speed shop, S&K Speed.
I'll have to let you all know how it turns out. I've been quite busy lately and my welding buddy is no where to be found. I might have to field the last section of welding to another shop in my area.
Re: Real world weight loss program and it` cost.......... [Re: The Driver] #1353923
08/20/13 10:10 AM
08/20/13 10:10 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
To the top.
Getting old just means you were smarter than some and luckier than others.
Re: Real world weight loss program and it` cost.......... [Re: dannysbee] #1353924
08/20/13 10:02 PM
08/20/13 10:02 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Recently I read this thread from start to finish! The most important tool in my shop for the racecar has been a bathroom scale!
This thread reminded me of a few ideas that I had forgotten!
One of them was switching my 5 steel hood pins to aluminum ones. I have 2 in the back and 3 in the front. I ordered the aluminum ones in 1/2 inch diameter and 4 inches long. When I went to swap them out I couldn't believe it when I got to the rears! My 2 rear pins were not only steel but they were 5 inches long with about an inch and a quarter sticking down under the bracket! I ended up cutting off some extra on 3 of the new aluminum ones. I weighed all the new ones and then all the ones I removed. The differance was just over 14 ounces or almost a pound off the front end!
Thanks for posting!
John
Re: Real world weight loss program and it` cost.......... [Re: moparjohn] #1353925
08/20/13 11:14 PM
08/20/13 11:14 PM
Do not remember if I posted this before on this thread being that it is rather long at this point, But I managed to remove about 10-1/2 Lbs off the front of the car by replacing the factory hood hinges, locks, latches and brackets etc. with steel hood snap pins. I then removed another 1-1/2 lbs with Aluminum types that I hand made and threaded using aluminum nuts and washers. Been on there for years now.
Found out that the circle track and midget car scene have aluminum hood pins in their arsenal of new parts.
I just found a super slick set of Black anodized aluminum hood pins at my local Speed shop, S&K speed on Long Island. Very nice if you want to go stealthy. You can see on the attached flick the hand made hood pin posts with their respective washers and pins. Black ones will be on there soon.
