Page 35 of 179 1 2 33 34 35 36 37 178 179
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353866
04/12/13 07:16 AM
04/12/13 07:16 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
On the topic ov aluminum exhausts...
I would imagine a system made from alum would have quite a different sound than mild steel. Almost everything out there is made from mild steel... from the primaries to the tailpipes. Stainless has quite a different sound, and as much as i'm obsessive and anal about weight savings, i'll be building a stainless system for that reason... they just sound cool. I'd think an alum system would be quite muted sounding, especially if the mufflers are aluminum too.
I'm a Spintech fan... and i'll be hoping they can make basic models out ov stainless. I wonder if they'd make them out ov aluminum if asked too? They are a very creative lot.
I know i'll be taking a big hit weight wise with a stainless exhaust, especially as it'll be 3", but at least building a T/A Challenger i dont need tailpipes. I built a 3" mandrel X-pipe system with Spintechs and T/A style exits for my 72 Charger (so maybe a few inches more pipe total), and it was pretty damn heavy...
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353867
04/12/13 09:04 AM
04/12/13 09:04 AM
fullmetaljacket Offline
Stainless doesn't have to be heavy gauge thus heavy in weight. My recent stainless tubing made out of wafer thin 314 military grade that I acquired from Burns stainless in California only weighed about 7 Lbs or so over my new aluminum pipes. The Mufflers are another story since the heaviest part of the system is usually the Muffs, that is why I went with aluminum.
Keep in mind that the gauge thickness also has a play on the sound decibels of a system. Too thin and you might as have open exhaust. I personally would love to be a little more quite anyway with aluminum to hide the intent of the package. My car already sounded kind of F1 with its X-tube, so no classic Mopar notes on the street.
Re: Real world weight loss program and it` cost.......... [Re: prochargedhemi] #1353868
04/12/13 10:36 AM
04/12/13 10:36 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
ill leave this here
OK, I have to ask. How much for a set of these? I don't have any for my Road Runner, and if I have to buy some, might as well be a lightweight set.
Jeff
69 GTX 68 Road Runner
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353869
04/12/13 09:06 PM
04/12/13 09:06 PM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Yeah, like chromoly you can make stainless a bit thinner, but like you said, then you start hearing more ov the exhaust... and not in a good way. In a thinwall old Hooker headers sort ov way. The systems i've heard that really turn me on are all very stout, and the ONLY place you hear the exhaust is out the tips... so i'll be looking at a penalty for that. Dammit.
If pure speed and stealth were my only criteria, then an aluminum system dumping under the seats or T/A-style would be the ticket. Man you could save a LOT ov weight doing that...
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353870
04/13/13 02:06 AM
04/13/13 02:06 AM
Sure can. I stand to drop at least 48 Lbs from my original mild steel tube exhaust of years back and about 25 Lbs from my previous stainless lightweight tube exhaust. Lets see if it lives though.
If it does not live, I'll go back to my stainless system while using the new lightweight Mufflers. I'll post some pictures of the system along with the Aluminum muffler hangers before it goes under the belly of the car.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353871
04/13/13 05:19 AM
04/13/13 05:19 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I cant see why it woudn't live... Whats the melting point ov aluminum anyways? If you're starting from headers it'd be even cooler on the pipes. Alum from the manifolds might be pushing it...
You gonna save 25lbs from the stainless to aluminum and still keep the same size/routing? or are you cutting more weight to get that like say, deleting tailpipes/running smaller pipe?
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353872
04/13/13 08:27 AM
04/13/13 08:27 AM
Just cautiously kidding. Aluminum starts to soften and melt at around 1250 degrees.
The gentleman making the mufflers has already made quite a few aluminum exhaust systems that have lived for years on project cars. It's all in making them start at the collectors and going back from there. The trick is to have them be as large diameter as possible so that the heat expands and actually cools better. They won't survive if they are 2" or 2-1/2" because they will hold more heat.
3" is the starting minimum.
My exhaust is 3-1/2 anyway to the X-pipe and then it narrows down to 3" all the way back where it ends and dumps just before the rear end differential. No tail pipes needed.
The only reason that manufacturers do not have them be standard equipment is probably the same reason that P-body mentioned. The exhaust gasses being as they are, carry a lot of toxic corrosive properties, so systems may not last as long in theory. My car is a week end thug, so it does not see many miles in a given year anyway. Aluminum does not rust, but it can oxidize and grow spores in a way.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353873
04/13/13 01:19 PM
04/13/13 01:19 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
the problems that i have run into with the aluminum exhaust is that after multiple heat cycles it becomes brittle. if you have it securely mounted it will crack along the mounting tabs
Re: Real world weight loss program and it` cost.......... [Re: prochargedhemi] #1353874
04/13/13 02:10 PM
04/13/13 02:10 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I noticed they sell a aluminum trans cross member for the 5.0 guys
Re: Real world weight loss program and it` cost.......... [Re: prochargedhemi] #1353875
04/13/13 07:25 PM
04/13/13 07:25 PM
I know and I have a special slip joint connection and firm rubber mounts to keep the vibration low. Vibration is aluminum's nemesis.
Stainless is also prone to cracking if it's too light gauge and not mounted correctly.
I'm curious to hear how it all sounds through the pipes.
Re: Real world weight loss program and it` cost.......... [Re: Scamp408] #1353876
04/13/13 07:27 PM
04/13/13 07:27 PM
Aluminum trans cross member, like if those little feathers need any more lightening. LOL.
Just saw a trunk model 90's Mustang idle by the block and it smelled like light weight. Those cars can benefit form weight gain.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353877
04/21/13 12:06 AM
04/21/13 12:06 AM
Aluminum mufflers should almost be ready. I will post flicks once I received them.
I predict 7 lbs each.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353878
04/21/13 12:26 AM
04/21/13 12:26 AM
State of confusion
Thumperdart Offline OP
State of confusion
Looking foreward......
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353879
05/04/13 02:00 PM
05/04/13 02:00 PM
A New York minute that we all have not spoken legend.
I figured that some of you that are still insane in the membrane like myself would like to have a peek into the Aluminum alloy front Drum hubs that Dr. Diff made. They are awesome and fit like a glove of course. The only glitch being the only offshore made item in the whole kit, the grease cap. This grease cap was stubborn to find its new home and I didn't want to pound on it even with the soft rubber mallet. I'll figure it out on how to seat it properly on the Hub later, but here's the stock one with the long 3" studs installed years back.
It weighs in at 5-1/2 Lbs as you see it here with only the rear bearing and races still in it.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353880
05/04/13 02:03 PM
05/04/13 02:03 PM
Here's the Aluminum Hub installed with out the castle lock cap on the nut of course. Each side weighs in at 4 Lbs even. This saved 3 Lbs total off the very front end along with a little amount of rotating weight removed because it's such a small moving part.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353881
05/04/13 02:07 PM
05/04/13 02:07 PM
With the lightweight Wagner drum sans cooling fins that add weight. With these on, I try and respect the power within. Not for those that are light at heart.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353882
05/04/13 02:29 PM
05/04/13 02:29 PM
State of confusion
State of confusion
NICE!..............
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353883
05/04/13 04:19 PM
05/04/13 04:19 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
Whats the spring for? Cooling?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Real world weight loss program and it` cost.......... [Re: fed] #1353884
05/04/13 05:53 PM
05/04/13 05:53 PM
Anti-vibration springs while in motion. I already lost the other side drum spring which must have flown off at some point with out me hearing or feeling it. I think a slight vibration now exist. I'll have to test in the next week or so.
These are the lightest drums on the market without mentioning the Aluminum GM types that could probably be adapted with a trick that I thought of a long time ago using a GM type bolting/end flange pattern.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353885
05/04/13 07:12 PM
05/04/13 07:12 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
...The only glitch being the only offshore made item in the whole kit, the grease cap. This grease cap was stubborn to find its new home and I didn't want to pound on it even with the soft rubber mallet. I'll figure it out on how to seat it properly on the Hub later...
At one time AndyF had an aluminum grease cap installation tool that could also be used to reshape dented caps. I don't know that it ever received an AR*** part number though. Perhaps you could spin caps out of aluminum? I don't see how a low-buck, malformed import part has any place on a car like yours.
