Re: What can you tell me about these Hemi Heads ?
[Re: HEMIFRED]
#1351674
12/15/12 04:15 PM
12/15/12 04:15 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Thanks, I sent them an email. If I can use them, great. But I will not put huge money into these just to get them to work. Already have to weld the injection ports closed.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: HEMIFRED]
#1351675
12/15/12 04:23 PM
12/15/12 04:23 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
They're late 70's early 80's fuel heads, look to be Brads or maybe Dart billets,like Fred said Total Flow could give that info. They and Airflow Research did the actual porting work on most of the fuel heads back then. The 16 bolts gave way to the 10-bolt manifold in mid-80's, the dual down nozzles in the intake port were only used for nitro. Looks like the last person to use them might have used them for alky though, since the spray bar channel is blocked and plugged at the valve cover line. Hard to tell from pics but looks like seats might still have some life in them, probably needs guides as fuelers usually run .002"+ stem clearance. Looks like someone just got PO'd at #7 exhaust and took a hammer to it. Yeah, they can be fixed, you'd just have to find a use for them, nostalgia, match, exhibition?? Without water capabilities, choices are limited.
[Re: 23T Hemmee]
#1351676
12/15/12 04:49 PM
12/15/12 04:49 PM
sunroofgtx
Cleveland
Unreal, so they are NOT water heads? Thank you sooo much for that info.
[Re: sunroofgtx]
#1351677
12/15/12 05:10 PM
12/15/12 05:10 PM
Posts: 1,505 TN
SCATPACK 1
TN
not water heads. Billet machined heads by appearance.
Old Geezer Racing
