69 Charger Splash Shield: Black or Body Color? #1351160
12/14/12 12:49 AM
12/14/12 12:49 AM
Arizona
69rrgrabber Offline OP
Arizona
Please see the pic below. This is a metal splash shield that goes under the frame/K frame on my 69 Charger and I am trying to figure out if it should be black or body color. I was going to go body color since the under body is body color but though I would get some advice.
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: 69 Charger Splash Shield: Black or Body Color? [Re: 69rrgrabber] #1351161
12/14/12 01:05 AM
12/14/12 01:05 AM
Those are supposed to be black. They were installed way after the the body was painted at the factory.
Re: 69 Charger Splash Shield: Black or Body Color? [Re: ] #1351162
12/14/12 01:12 AM
12/14/12 01:12 AM
Arizona
Arizona
Thanks for your response, would it be flat or gloss? Also trying to figure out what color to paint the K frame to radiator support tie bracket, and the battery tray with brackets.
THanks,
CAC
Re: 69 Charger Splash Shield: Black or Body Color? [Re: 69rrgrabber] #1351163
12/14/12 01:21 AM
12/14/12 01:21 AM
semi gloss for that and the k frame bracket. Battery tray and brackets are body color.
Re: 69 Charger Splash Shield: Black or Body Color? [Re: ] #1351164
12/14/12 03:23 AM
12/14/12 03:23 AM
Arizona
Arizona
Thanks again!
Re: 69 Charger Splash Shield: Black or Body Color? [Re: 69rrgrabber] #1351165
12/14/12 10:20 AM
12/14/12 10:20 AM
the Netherlands
Mr4Speed Offline
Mr4Speed  Offline
the Netherlands
For what it's worth; i removed the panels from my 63 Savoy; unrestored car; under the factory undercoating i found that the plates were grey instead of black; i also had a grey k-member and transmission cross-member; but in most occasions the plates should be black indeed.
