Original B1 head rockers #1351011
12/13/12 08:12 PM
12/13/12 08:12 PM
Louisiana United States
E
E422MIKE Offline OP
E422MIKE  Offline OP
E
I have a 500ci. low deck engine that belong to a friend, he always had trouble with rocker arm adjuster screws gaulding to pushrod cup. The engine has original B1s with black rockers that came with heads from koffels. Do I need T&D rockers that oil thru push rods? The engine is aluminum rod,738 lift roller cam. Drag Race engine, Any help would be greatly apreaciated. THANKS.
Re: Original B1 head rockers [Re: E422MIKE] #1351012
12/13/12 09:08 PM
12/13/12 09:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would prefer the T&D rockers and pushrod oiling but they are not necessary for what you have. You need to make sure you have the correct length pushrods in the motor. If the adjuster stud is to far out or not enough you can have problems like you describe. Also make sure that the rocker shafts are installed in the correct orientation.
Re: Original B1 head rockers [Re: Al_Alguire] #1351013
12/13/12 09:36 PM
12/13/12 09:36 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
The only time I have had a problem in 10 years with burning pushrod cups using Koffel rockers I accidently put the shafts in wrong and the oil wasn't getting to the cups.
Re: Original B1 head rockers [Re: mac56] #1351014
12/13/12 10:15 PM
12/13/12 10:15 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
afaik those rockers are made by dove and while some have used them successfully for the most part it's only a matter of time before you end up with T&D or Jesel. imho if you can swing it financially i would upgrade the rocker system.
Re: Original B1 head rockers [Re: jamesc] #1351015
12/13/12 10:51 PM
12/13/12 10:51 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
as mac56 said, the shafts only go on one way , and the bottom of rocker to bottom of ball is .375 thou. Are they 3/8ths push rods? The cup is 3/8 ths on mine. I'm steppin up next year tho. Cab has a brand new set he wants to sell complete if you need any, drop him a PM
Re: Original B1 head rockers [Re: mac56] #1351016
12/13/12 10:52 PM
12/13/12 10:52 PM
E
E422MIKE Offline OP
E422MIKE  Offline OP
E
Can I use the T&D shaft mount rockers? THANKS!!
Re: Original B1 head rockers [Re: Mopar-Al] #1351017
12/13/12 10:58 PM
12/13/12 10:58 PM
E
E422MIKE Offline OP
E422MIKE  Offline OP
E
Yes they are 3/8s push rods. thanks everyone for the input.
Re: Original B1 head rockers [Re: mac56] #1351018
12/13/12 11:07 PM
12/13/12 11:07 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
What the first two said!
Re: Original B1 head rockers [Re: camastomcat] #1351019
12/14/12 03:16 AM
12/14/12 03:16 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes you can use the T&D common shaft rockers, just bolt right up but likely will need new pushrods. But check what you ahve first, might be a simple solution.
