440 engine specs #1350973
12/13/12 05:46 PM
12/13/12 05:46 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Can someone tell me the bore size wear limits and taper for standard bore. ie 4.320 +.008 with a .012 taper.
Re: 440 engine specs [Re: johnfin] #1350974
12/13/12 05:52 PM
12/13/12 05:52 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Factory specs:
Cylinder Bore, Max out of round .005"
Cylinder bore taper, max .010"
when reconditioned, both should be brought back within .001"
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 440 engine specs [Re: VincentVega] #1350975
12/14/12 05:50 PM
12/14/12 05:50 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Bores are larger on the bottom of the skirt from wear due to the geometry of the rod angle, right?
Re: 440 engine specs [Re: johnfin] #1350976
12/14/12 06:35 PM
12/14/12 06:35 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
No, pistons have a slight taper. When you measure for wear, you measure the piston perpendicular to the wrist pin.
Re: 440 engine specs [Re: johnfin] #1350977
12/14/12 08:41 PM
12/14/12 08:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
No. Not wider at the bottom.
Re: 440 engine specs [Re: BSB67] #1350978
12/14/12 11:44 PM
12/14/12 11:44 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I dial bore checked my block and its larger at the bottom of the bore.
Re: 440 engine specs [Re: johnfin] #1350979
12/15/12 02:51 AM
12/15/12 02:51 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's very odd.
