Quick Fuel Carb 750 Annular ON A 318 #1350373
12/12/12 03:44 PM
12/12/12 03:44 PM
Cape Coral
65 DODGE POST Offline OP
Cape Coral
I am running an odd ball setup....but wanted to try it anyway.
Last month I ported my stock exhaust manifolds and ran the car with a vacuum secondary 650... The outlet on my exhaust manifolds were 1 3/4" The largest jets I had were 73 primary 78 secondary...went 13:90 @97 MPH.
So I coughed up the $$ and bought some TTI headers and opened up the flanges a little to match my W2 ports. These are 1977 heads with the stock exhaust bolt pattern only. I also bought a 750 annular carb.
I found out from others that I should probably lean the carb out so I went with 70 jets front and 78 rear....
Took it to the track and it ran a low 14 at 75 mph....surging...( I should have got out of it, but you know how it is)
I switched to 83 rear jets and tried again and got 94 MPH out of it.
Testing was over...drove home bummed out, and threw some 72 jets in the front on the way home....felt a little stronger...
Having read everything off the internet with annular boosters I was thinking I did not have to jet up....but with a large intake with a 3/4 spacer ( Nitrous) large runners from the W2's and only 322 cubes I did. Installed 76 jets front and 87 rear took the car for a ride and it felt like it had 75 more horse...A little closer to what I'm used to. I still felt a little lean miss from 5000 to 6200...but it pulls strong from 3500 to 5000... I am just going to reduce the HSAB from .031 to .029 and try that. Tracks are closed by me and I do not have a wide band..
I really want 400 horse out of this little guy... I have seen 4 or 5 other builds with less head make 400 ponies... It feels like it has about 350 right now.... My last two cars ran high 11's and this one just doesn't feel that strong yet...But to try and get it there with a 318 is fun.
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350374
12/12/12 04:32 PM
12/12/12 04:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Remember if your running pump gas, the jetting needs to go up due to the 10% Ethanol....Target A/F is no longer 12.8:1 its closer to 12.5:1..All those specs are real 'gas', not the crap we run on now a days.
Re: My New Quick Fuel Carb 750 Annular [Re: Dragula] #1350375
12/12/12 05:51 PM
12/12/12 05:51 PM
Cape Coral
Cape Coral
Makes sense..helps explain my larger jets a little also.
65 DODGE CORONET 440 INDY EZ HEADS STRANGE S60
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350376
12/12/12 06:04 PM
12/12/12 06:04 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I wouldn't mess with the HSAB until you get the WOT jetting correct. It's not there at all if it's falling off above 5000.
Fuel delivery a possible issue?
A big jet spread like what you have can hamper the overall WOT performance. Get the spread closer together, usually about 6-8 sizes running a holley, unless the PVCR is really opened up.
Looks like those carbs may come with a 12 step spread, which would imply a rather large PVCR.
Re: My New Quick Fuel Carb 750 Annular [Re: RobX4406] #1350377
12/12/12 06:10 PM
12/12/12 06:10 PM
Cape Coral
Cape Coral
Yes it is actually....stock ( NAPA ) mechanical pump 6.5 psi at 23 gph....It fills the bowls pretty quick.....but it's definitely not enough....I was just doing first and second gear pulls....but I bet that is my problem.
Now that I think about it.... I am not touching the carb until I change the fuel pump....because It pulls pretty hard in first gear
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350378
12/12/12 06:18 PM
12/12/12 06:18 PM
RobX4406 Offline
RobX4406  Offline
What was the stock jetting in your QF carb?
I'd have started there and worked up or down.
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350379
12/12/12 06:21 PM
12/12/12 06:21 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
if you are using a stock fuel tank it could also well be you are uncovering the pickup while racing it.
I made the mistake one time at a big event having the tank only half full( compared to the normally topped off) and the car died about 1/2 track, let off and it would pick up again.This with a stock tank and 3/8 pickup.
Check that as a possible issue, it could be the mechanical pump the previous poster mentioned as well, but that seems more unlikely to me, but its certainly possible as well.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: My New Quick Fuel Carb 750 Annular [Re: RobX4406] #1350380
12/12/12 06:22 PM
12/12/12 06:22 PM
Cape Coral
Cape Coral
It came with 70/83's
I did start there....but this thing feels like a whole different motor with the 76/87 jets in there now.....
Re: My New Quick Fuel Carb 750 Annular [Re: B3422W5] #1350381
12/12/12 06:28 PM
12/12/12 06:28 PM
Cape Coral
Cape Coral
You know what....It did cut out on me at the track in 3rd gear....with less than a 1/2 tank. Thank you for this tip. I could not figure it out....I was thinking to my self this thing can't be sucking that much fuel that the pump cant keep up for 13 seconds?
I have a brand new 1/2 inch pick up and a 3/8's pick up to install. I'm not sure which one I should install... I was going to wait to get an electric pump and install everything at once.
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350382
12/12/12 06:30 PM
12/12/12 06:30 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
If you are starving it at the top end due to the fuel flow, then you may need to rejet again after you have the proper fuel flow.
When my fuel pump was going bad, It was going lean on the top and I could not put enough jet in it to change the A/F at WOT. Then once I found the fuel pump problem, it was too rich and I had to jet it back down.
Are your float levels in the middle?
Glad to see that it is running better for you!
Re: My New Quick Fuel Carb 750 Annular [Re: YO7_A66] #1350383
12/12/12 06:44 PM
12/12/12 06:44 PM
Cape Coral
Cape Coral
That is what I'm thinking..... I bet the jetting is real close I'm going to wait till I install the new line and pump.
Floats are in the middle...Thanks for all your help Dave....
Since I'm going to spray this thing I am going to get a HP holley electric pump with a regulator... 3/8 line with either a 3/8 sending unit or 1/2 "
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350384
12/12/12 06:51 PM
12/12/12 06:51 PM
Renton Washington
Triple Threat Offline
Renton Washington
What are the incremental times?
60
330
1/8th
1/8th mph
1000'
1/4
1/4 mph
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350385
12/12/12 07:08 PM
12/12/12 07:08 PM
Dude, your hooked on going fatser now so put the 1/2 pickup and line on it now Also make sure and buy the correct electric fuel pump, not one that might work Way cheaper to do it once than to do it over and over, like some of us dummys Don't start with a Holley or Mallory 140 or 140 pump, jump up and put your big boy pants on and buy a 250 or bigger pump to start with I like and use Magnfuel pumps, make sure and follow there instructions on line size a fuel filer micron size and location also IHTHs
Re: My New Quick Fuel Carb 750 Annular [Re: Triple Threat] #1350386
12/12/12 07:08 PM
12/12/12 07:08 PM
Cape Coral
Cape Coral
60 2.02
330 5.8
1/8th 8.9
1/8th mph 78
1000'
1/4 13.9
1/4 mph 96
I'm to embarrassed to say!!!
It actually 60' better with the 750 DP than with the 650 vacuum secondary..... and the DP has a pretty good bog to it from not enough squirt.
( but I almost have that fixed)
Now that I have went up 6 jet sizes front and 5 in the rear it feels like it's in the 12's easy.....but starts to fade at the top of second....so It's gotta be my stock 5/16's fuel pick up and line with my stock pump.....this car was a 6 cylinder car..
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350387
12/12/12 07:17 PM
12/12/12 07:17 PM
Renton Washington
Renton Washington
I went 12.30@107 with stock tank, pick up and fuel lines in a /6 car. Only change was a Carter fuel pump. Other people have gone much faster. Change the pump and try again.
-Dustin
Re: My New Quick Fuel Carb 750 Annular [Re: Cab_Burge] #1350388
12/12/12 07:19 PM
12/12/12 07:19 PM
Cape Coral
Cape Coral
Funny you say that because I was going to get the 150 gph and regulate it...I already have the 3/8 braided line that's why I was going to run that.... but you are right.....the better pump and line would be the way to go since I have the 1/2" pick up sitting here....
I will hit this with a 250 shot....after I get it dialed in... I was originally going to turbo the car and had Dynamic build a converter for the turbo....so it is a little tight on horsepower....it only flashes at 3500..... But I figure with a 250 shot it will leave just fine...
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350389
12/12/12 07:22 PM
12/12/12 07:22 PM
Portage,michigan
Portage,michigan
Before you throw a lot of money at it, next time at the track just make sure your tank is completely full, so as to help eliminate the fuel slosh problem.
Jets can effect the tune , no doubt about it, but the issue you are having is more catastropic than jet changes alone would make..unless something is ultra wrong with that carb..float adjustment way off, etc, etc
Btw, it wont matter at your current power level which pickup you install,( i went mid 10's with a 3/8 pickup and stock tank) but understand, no matter the pickup size, if its getting uncovered by slosh, it will cut out on you. Your fuel line going to the engine is still gonna be the same size, and the bowls are still gonna be the same size, as are the needles and seats
1.41 best 60 foot
6.56 at 104.17
Re: My New Quick Fuel Carb 750 Annular [Re: Triple Threat] #1350390
12/12/12 07:23 PM
12/12/12 07:23 PM
Cape Coral
Cape Coral
I went [Email]12.30@107[/Email] with stock tank, pick up and fuel lines in a /6 car. Only change was a Carter fuel pump. Other people have gone much faster. Change the pump and try again.
Thanks for that Dustin... You are about where I want this car to be on motor...definitely going to change the pump
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350391
12/12/12 07:30 PM
12/12/12 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Quit guessing... when doing ANY TESTING you need some
gauges to verify what is REALLY happening... put a
gauge on the fuel before the carb... tape it to the
windshield if you need to... see if you are running
out of fuel... also that carb has a .110 needle and
seat so after you test with a gauge it will either
so a big pressure drop with your currant set up or
it wont and if it shows good pressure change to a
.120 N/S
Re: My New Quick Fuel Carb 750 Annular [Re: MR_P_BODY] #1350392
12/12/12 07:37 PM
12/12/12 07:37 PM
Cape Coral
Cape Coral
.120 N/S
This is good affordable advice....thanks....I can tape a gauge out there and take it out in the back roads and try it out in 2nd to 3rd gear....I just have a feeling the gauge is going to drop to 0 pressure after I'm on it for a couple seconds....It's a Napa pump I threw on there because my 110 holley broke.... I picked it up from napa for 19 bucks I think..was desperate to go to the track that day.
Re: My New Quick Fuel Carb 750 Annular [Re: 65 DODGE POST] #1350393
12/12/12 07:38 PM
12/12/12 07:38 PM
I bought a wide ban O2 system several years back for my car, all the engine dyno shops I use have dual wide bands on thier dyno, annular boosters are famous for going richer the higher you rev the motor, if you have enough fuel supply BTW, there is no way I would buy the 250 or 275 pump knowing I was going to hit it with a 250 NOS shot unless you have a seperate, adequate, fuel system for the NOS. I bought a Magnafuel 500 pump for my next car, that motor will make 900 +HP N\A Magnafuel says there 275 pump are good for 750 HP, the 300 pumps are good up to 900 HP and the 500 pump is bigger and better yet I have all three plus two BG 400 pumps Some lessons are hard learned for some of us
