freshening a 727 for 650hp sb #1349150
12/10/12 03:46 PM
12/10/12 03:46 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Going to pull and freshen my 727 this winter. Would like to ask your opinions as to what to put in it. Running a trnsbrake in a 3300# car. Trans has alto reds and kolenes billet servos standard bolt in sprag. Drums and other internals are oem except the a&a manual tb vb and the deep pan. Should it have anything roller or extra beyond what it already has at this 6oo+hp level? Thanks
Re: freshening a 727 for 650hp sb [Re: mopar dave] #1349151
12/10/12 03:58 PM
12/10/12 03:58 PM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
Get this front band
http://www.transmissioncenter.net/727transmission.htm
Extreme Duty Brass Impregnated Carbon Fiber Flex Band.
Cheap and very good!
Also 4.2:1 ratio band lever and HD band strut would be nice upgrades.
For safety, it is recommened to use billet steel or aluminium front drum. If you use it on street, go for steel.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: freshening a 727 for 650hp sb [Re: Ck[FIN]] #1349152
12/10/12 04:12 PM
12/10/12 04:12 PM
Mt Morris Michigan
Mt Morris Michigan
I do have a 4.2 lever and vb is rear band apply.
Re: freshening a 727 for 650hp sb [Re: mopar dave] #1349153
12/10/12 10:55 PM
12/10/12 10:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Upgrade the drum.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: freshening a 727 for 650hp sb [Re: hemi-itis] #1349154
12/11/12 01:06 AM
12/11/12 01:06 AM
Mt Morris Michigan
Mt Morris Michigan
Ok what are the benefits of up grading the drum besides it wont explode? Having a rear band apply and bolt in sprag im safe from the stock drum exploding. Right? This how i understand it at this point. Also rollerizing does nothing for ET so why bother.
Re: freshening a 727 for 650hp sb [Re: mopar dave] #1349155
12/11/12 01:08 AM
12/11/12 01:08 AM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Put a 904 in it!
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: freshening a 727 for 650hp sb [Re: mopar dave] #1349156
12/11/12 02:13 AM
12/11/12 02:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your fine with what you have... the ONLY thing I
would add would be a A&A super sprag... rollerizing
it wont gain you at all
Re: freshening a 727 for 650hp sb [Re: MR_P_BODY] #1349157
12/11/12 11:02 AM
12/11/12 11:02 AM
Mt Morris Michigan
Mt Morris Michigan
Ok thanks guys. My tranny man says the same for rollerizing. He thinks the standard bolt in sprag is good enough,but ill have him put in a super sprag and just freshen the kolenes and altos.
Re: freshening a 727 for 650hp sb [Re: mopar dave] #1349158
12/11/12 11:37 AM
12/11/12 11:37 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Not tryin to steal the thread but my guys says stk clutches are fine for a 727 till the 9s or turbo/blown/nitrous deals.
