Re: cable or solid rod for gas pedal
[Re: jamesc]
#1349137
12/10/12 11:00 PM
12/10/12 11:00 PM
Posts: 7,506 Az
Crizila
Az
Cable. Makes life a lot easier.
Fastest 300
[Re: Crizila]
#1349138
12/10/12 11:31 PM
12/10/12 11:31 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I bought a lokar cable years ago. I went for the bling. It consisted of brackets and stops. But the worst was the housing. It was just a teflon braided line. Well guess what the cable cut into the teflon and the throttle hung. I use motorcycle or bicycle cable housing now. And buy the inner cable at lowes. Been working for years.
[Re: Leon441]
#1349139
12/10/12 11:49 PM
12/10/12 11:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being that I worked in the Fuel and exhaust lab I made my own cables for my set up... the first week or so when I built my car I used the old throttle cable (/6) and of course it broke launching off the line... so I made a new one and made a back up... and based on Murphy's law... since I have 2 it will never break.... and it hasnt since... lol
[Re: 3404]
#1349142
12/11/12 12:11 PM
12/11/12 12:11 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A morse cable will push as well as pull, stock type cables will not. The choice between a morse cable and a solid linkage will depend on the application and preference. A cable does allow more creativity. Anything beyond a stock OE/street type set-up, I personally would not use a stock style cable and I would have some kind of a toe hook on the pedal. I like the idea of being able to pull the throttle shut with my foot.
[Re: Crizila]
#1349145
12/11/12 09:23 PM
12/11/12 09:23 PM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
I always had faster reaction times with a rod, I guess because of more friction with a cable with bends.
I used to have that problem - - - - when I was 20!! [/quote
Silly guy ha ha
[Re: 3404]
#1349146
12/11/12 09:27 PM
12/11/12 09:27 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My DartSport had a solid rod, once setup it was easy to use and no maintenance.
My 69 Dart had a cable and boy did I have headaches with it. I bought a good stainless bicycle cable and redrilled the gas pedal so the cable was aimed perfectly straight into the cable tube. The main thing is that the cable can not have any extra tension on it after the carb has reached full throttle! If there is even a tiny amount of play left in the gas pedal after full throttle you will break the cable. I broke 3 before I got it all figured out.
[Re: ProSport]
#1349147
12/11/12 09:51 PM
12/11/12 09:51 PM
Posts: 1,288 Oregon
sg66mopar
These people will make you any kind of cable you need. Most of the racers in the Portland (Oregon) area, including myself, buy throttle cables from them. http://www.instrumentsales.com/(503) 239-0754 (800) 333-7976 The last one I bought was last year. It's about 18" long, bullet proof and only cost about 40 bucks, built to my specs.
[Re: sg66mopar]
#1349148
12/12/12 01:01 PM
12/12/12 01:01 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Gus I have the same bracket.I got it from Mancinis for like 20 bucks at Carlisle.Works great with the M1 and Dominator.Rocky
Chrysler Firepower
[Re: therocks]
#1349149
12/12/12 01:11 PM
12/12/12 01:11 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
All cars that leave my shop to be raced have a solid rod and a toe clip for safety.
BB, TT5,Procharged 3300lb Street Car 4.79/154
