Re: Roller Rockers VS Flat Tappet
[Re: LA360]
#1348382
12/11/12 06:36 PM
12/11/12 06:36 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
We have the econo so they would probaly be unbushed. So what is the difference between bushed and unbushed?
The bushed ones have a bronze bush in the rocker shaft bore
your rockers dont know if the heads are econo or not, so its a crap shoot as to what you have, bushed or not. I bought a set of heads and there was a box of extra parts and there was no ryme or reason, I had a few bushed and a few not.
They were great in the 70s, but not so great with todays technology, but some NHRA rules require the use of stock rocker gear IIRC, and most guys will send these in to have the geometry corrected and then ya have a knows good set of rockers.
My vte is ya step up to either Harlan Sharp, Jessel, or T&D, or if you happen to find a used set of norris rockers those babys are awesome.
[Re: Moparnut426]
#1348383
12/11/12 07:17 PM
12/11/12 07:17 PM
Posts: 3,395 Pa
Hot 340
Pa
[My vte is ya step up to either Harlan Sharp, Jessel, or T&D, or if you happen to find a used set of norris rockers those babys are awesome.
Its so easy to spend other people's money aint it? Cab, how did RAS correct the ratio's? Obviously you can move the threaded adjuster hole...did they use an offset bushing??
[Re: Hot 340]
#1348384
12/11/12 11:09 PM
12/11/12 11:09 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I ask them about the way they correct the ratio, the responce was that they change the adjusters from 3/8 to 7/16 inch diameter and move the center of the adjusting hole to correct the geometry from the center of the shaft to the rocker arm tip(they would grind it and heat treat the rocker arm tip when done) and the center of the shaft to the center of the adjsuter hole, Thats what they said in 2001 or so the best I remeber it They did say that they wouldn't try and offset the shaft bushings as that was to hard to control the centers on
