Re: Mancini racing billet rear main seal?
[Re: quickd100]
#1347856
12/09/12 10:25 AM
12/09/12 10:25 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I build a lot of Chrysler B motors. Through much aggravation, here is what I discovered about the BBM rear seal.. -I ONLY use the reddish brown colored Fel Pro "fluoroelastomer" seal. It cost around 30 bucks so its not cheap, but I dont waver here. -The premium cranks with the smooth RMS surface I never run into a problem. The Chinese cranks with the knurling on the RMS surface has given me some problems. Some of these have very aggressive knurling that, I believe, tears up the rms lip. I always send those cranks to the crank guy for checking and correcting anyway and we usually take .006 off the surface of the RMS area. That makes it smoother and knocks down the high spots. A rope seal would peobably work in this case with no mods-but I dont want to deal with that. -The new billet RMS retainers are nice, but I found one flaw. If you look at the piece when its installed, it seems to "shroud" the area around the rearmost main cap. While this is only a theory on my part, I think the oil(especially when cold) can build up back there and not adequately drain. To correct this I mill a slot about 1.5" wide to give some room for better drainage. Its no big deal. If you want to see a cap that I think is done right, its the one that Best Machine sells. Its anodized red in color and has the relief that I mentioned already in place. Ill see if I can post up some pics later. Nothing ruins a nice engine build more than a friggin rear main seal leak... MB
[Re: HPMike]
#1347857
12/09/12 12:12 PM
12/09/12 12:12 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Not a hemi, but I had a terrible time with my 512 stroker. I replaced the seal 3 times with the stock seal holder. Everyone would hold for a week or two, and then leak. I finally put the billet holder in, and so far, everything is nice and dry. I had never had a seal problem before this motor.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: turbobitt]
#1347859
12/09/12 12:43 PM
12/09/12 12:43 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Another important thing to note is seal alignment. A factory rope seal has the benifit to a large contact area and is not citical to seal retainer alignment. The aftermarket neoprean and flouroelastomer seals only have a small knife-edge contact to the crang. Any missalignment from upper to lower half can cause leaks. The only two ways to garranty no leaks is to align the seal retainer using both seals installed in block and cap but without crank installed then scribe a mark to indicate alignment, or the crank is already installed stagger the halfs so that it will garranty alighment. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#1347860
12/09/12 04:09 PM
12/09/12 04:09 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"A factory rope seal has the benifit to a large contact area and is not citical to seal retainer alignment. " This is a 4.5 Callies crank! Wonder if I should just try a rope seal with my original Mega block seal holder before I fork out the $70 for a hit or miss chance??? Has anyone tried this? Thanks Mike
[Re: 70satelliteguy]
#1347861
12/09/12 04:44 PM
12/09/12 04:44 PM
turbobitt
Southington Ct.
Caution - The rope seal needs a crank knurl to work. You would burn the rope seal without it.
Allan G.
#1347862
12/09/12 07:28 PM
12/09/12 07:28 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have used the factory cast units for years then I bought a few of them from Muscle Motors they both worked perfectly The one in my engine is dry and I also used one in a street engine I built for another member here with no complaints so far I had to trim mine for the studs but with ARP bolts it fits tight Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: turbobitt]
#1347863
12/09/12 07:32 PM
12/09/12 07:32 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Allan G.
If its a callies, its smooth. Ive not had any problems using the billet retainer(modded-or use the one Best Machine sells), with the orange seal on these.
MB
[Re: 383man]
#1347866
12/10/12 03:41 PM
12/10/12 03:41 PM
Posts: 1,301 Penna
70satelliteguy
Penna
I guess I will give it a shot on one of these Billet retainers since I will not be able to try the rope seal with my Callies crank. Thanks All Mike
#1347867
12/10/12 04:02 PM
12/10/12 04:02 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
https://board.moparts.org/ubbthreads/show...rue#Post7391808Here is what I have done and so far for me it has worked well. I WISH I had the true answer to why these are such a pain....It seems like everybody that has a problem is using aftermarket cranks so I believe the problem starts there.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
