590HP W2 headed pump gas 408 on the dyno...
#1347177
12/07/12 12:00 AM
12/07/12 12:00 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Got Daryl's W2 408 on the dyno today. We first ran an M1 intake that I ported and then ran his old Victor that I had ported. Tried a 950HP and a true 950. Best power was with the Victor, 1" open spacer and true 950 carb. 10.4:1 compression, street solid roller cam and TTI 1 7/8 headers. Link to one of many dyno pulls: http://youtu.be/WI1VQyyarwY
Re: 590HP W2 headed pump gas 408 on the dyno...
[Re: Moparnut426]
#1347192
12/07/12 01:56 PM
12/07/12 01:56 PM
Posts: 3,422 Toronto
mshred
Toronto
Honestly that engine is not too far off mine with the exception being your camshaft and rockers, I have Sharps and split 1.6 intake, 1.5 exhaust because thats what I had laying around.
Im also running Indybrocks.
Im no where near that HP number, like a good 90 HP off, but man there is great potential in these engines.
Nice Work Brian!!!
Kasey, are you running a solid roller or hydraulic roller?
[Re: Brian Hafliger]
#1347194
12/07/12 03:26 PM
12/07/12 03:26 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Brian Good power. Makes almost as much as my 440 RB and mine's over 12.5.1 comp. What was the true 950 carb specs ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
#1347196
12/07/12 05:07 PM
12/07/12 05:07 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Brian what are your thoughts regards a wide( 112) cam on a low compression motor? I suspect it helps a little with idle,driveability somewhat etc, but my experience is wide lsa n/a with low compression is that it adversely effects acceleration compared to something tighter, like a 108, particularly in the 60 foot. Just a lot doggier out of the gate in my experiences... Nice motor....
[Re: B3422W5]
#1347197
12/07/12 09:46 PM
12/07/12 09:46 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I like tight lca's most times but everything is a compromise! A smaller cam on a tighter lca would make more lower rpm power I'm sure, but for street cars traction is limited on the STREET so actually a good race HP and TQ curve work well. At the track, sure more poop on the line would be nice, but I'll bet the engine spends most of it's time in the 5000-7000rpm range and with a 4" crank even if the 60ft. is a little soft it'll e.t. better this way than the other.
Brian Hafliger
[Re: Stroker Scamp]
#1347199
12/07/12 11:03 PM
12/07/12 11:03 PM
That man knows what he is doing!!!--Nice build--amazing results! I love a unit that revs like a chainsaw!!!
[Re: mshred]
#1347204
12/08/12 04:03 PM
12/08/12 04:03 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Most dyno videos are boring but I really enjoyed this one, engine sounds great! That will be a blast in a fairly light weight car.
[Re: ProSport]
#1347205
12/08/12 08:03 PM
12/08/12 08:03 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Thanks Pro...Matt I would guess around 25-30HP maybe...as smooth as these lobes are, not sure it would be a huge amount. Remember, the heads were only mildly ported so there's some power left on the table there.
Brian Hafliger
#1347206
12/08/12 10:38 PM
12/08/12 10:38 PM
mshred
Toronto
Cool, I was just wondering if the solid roller helped make substantially more power if it was to be up against a similar flat tappet. Motor sounds BAD when it is revving
