Gas tank patina #1346921
12/06/12 02:26 PM
12/06/12 02:26 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
My original gas tank for my Duster 340 is not worth saving. New/ reproduction gas tanks are available. I know that some like the shine of a new tank but I was wondering if there some way to speed up the "aging" process and dull a new tank to give it a slight patina.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Gas tank patina [Re: FJR doc] #1346922
12/06/12 02:46 PM
12/06/12 02:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
just an FYI , the current available tanks are a one size fits all and the bottom side does not look correct in anything newer than 1967 .
Re: Gas tank patina [Re: FJR doc] #1346923
12/06/12 05:03 PM
12/06/12 05:03 PM
california
Mr D21 Offline
Mr D21  Offline
california
if your car was factory undercoated - then that could be a solution by spraying new undercoating on the tank
Re: Gas tank patina [Re: Mr D21] #1346924
12/06/12 05:35 PM
12/06/12 05:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Galvanizing seems to age pretty quickly in the sun, but maybe a mag/chrome wheel cleaner or oven cleaner would accelerate that, but I have no direct knowledge on the topic. Maybe spraying over the tank with a flat clear?
