Re: Low Deck 400 Combos....
[Re: old yeller]
#1346797
12/08/12 09:08 PM
12/08/12 09:08 PM
Posts: 2,449 nc
earthmover
nc
Are we just talking about factory Low decks?
lets hear that combo bird..what makes the bird fly
[Re: earthmover]
#1346798
12/08/12 11:46 PM
12/08/12 11:46 PM
Posts: 553 Kentucky
clovis
Kentucky
451 - Stock 440 crank, Stage VI heads, Mopar 590 cam, 13:1 compression, Indy 440-3, Quick Fuel 1050. 3300 lbs at the line, 6.25/110 1/8 9.86/135 1/4
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: earthmover]
#1346799
12/09/12 02:10 AM
12/09/12 02:10 AM
Posts: 728 mi usa
old yeller
mi usa
Jack Daniels on the rocks!!..lol
[Re: 70Dart499]
#1346801
12/09/12 01:02 PM
12/09/12 01:02 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My old DartSport now owned by 73DartSport, pump gas 451" low deck(just a 440 crank in a 400 block), half filled, 590 purpleshaft MP cam, CNC ported Eddy heads, 2" headers, M1 tunnel ram, 2 750 Quickfuel carbs, 1.6 Harland Sharp rockers, 6.20's and 9.80's at 3050 total pounds with driver. Most fun and reliable(and streetable) combo I've ever ran.
Edit: I mentioned half fill in the block but I may be wrong, I dont think this 451 had any block filler. The purple 69 Dart had a 500" low deck that was half filled. Aluminum main caps on both motors.
[Re: 440Jim]
#1346805
12/09/12 09:25 PM
12/09/12 09:25 PM
Posts: 4,070 Mo.
racerx
Mo.
Who else here is running a Low Deck 400 combo?
Never been on a dyno, but it's run 6.80's in my 3200 pound Dart,
Mine has not been on the dyno either, but it has run 5.75 in my 3250 lb Dart. More typical weather 5.85 1/8, 9.28 1/4
400 block, 4.375" bore 4.250" Callies crankshaft, 511 CID 6.535" H-beam rods, 2.2" (Chevy) rod journals 13.5 CR Comp Cams MM305S solid lifter, flat tappet cam 279/287 at 0.050", .650"/.630" lift (published) Indy 440-1 heads, milled to 68cc, some porting Indy 400-3 intake, single four, 4500 pattern 2-1/8" x 32" headers
Block filled to 2.6" from the deck Aluminum main caps
440 jim just curious what rear gear r u running in that car?And what r u trapping at?Not meanig to high jack....
[Re: badplymouth67]
#1346809
12/10/12 03:07 PM
12/10/12 03:07 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
Some minor details. 525" Low deck, B1MC heads, Bullet roller, CP Pistons 15.2-1 GRP rods, Callies crank, cast unported intake, Gary Williams Dominator, made 1050 on the dyno.
[Re: Al_Alguire]
#1346810
12/10/12 04:03 PM
12/10/12 04:03 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Would that low deck block be of the aluminum KB variety
[Re: Cab_Burge]
#1346811
12/10/12 04:25 PM
12/10/12 04:25 PM
Posts: 153 Plant city fl
70Dart499
Plant city fl
Another question for you guys, say I wanted to replace the 906 heads on my 499 with some better flowing aluminum heads, what would be the best choice without buying different headers, pistons or rocker arms? Thanks!
1970 Dart Drag Car
