Header Paint ?
#1345137
12/02/12 08:37 PM
12/02/12 08:37 PM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
I can't afford a coating so I'm looking for advice on header paint and it's application. What works and how should I prep the headers?
Thanks Butch
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
Re: Header Paint ?
[Re: Butch]
#1345138
12/02/12 08:41 PM
12/02/12 08:41 PM
it all stinks and smokes when you first fire it up and then whatever stays on is good to go for a season--just make sure all oil etc is off--clean em good--it will spray right over any minor rust and turn out OK--blasting beforehand defeats the cheapo part IMO--and the stuff still is just so so I plan on doing a set of dragster headers next week--coating just too high for cheapo headers--ok for high $$ headers IMO
Re: Header Paint ?
[Re: wj440]
#1345142
12/02/12 09:52 PM
12/02/12 09:52 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I've had both,and being that I'm anti PC...I'm happy as a clam with my VHT painted headers.
But I live in the desert, we pay extra for rust here.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Header Paint ?
[Re: wj440]
#1345145
12/03/12 06:08 AM
12/03/12 06:08 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Char-Broil Black Grill Paint ...let you know how it works next yr.
For whatever reason, I have found that this paint on headers is bullet proof...if you heat the pipe just before you spray it on.
Re: Header Paint ?
[Re: bobs66440]
#1345148
12/04/12 06:39 PM
12/04/12 06:39 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Butch I might have some of that Eastwood bright silver header paint left if you want to use it. Best stuff I ever used, I thought you had some.
Re: Header Paint ?
[Re: ProSport]
#1345150
12/04/12 08:28 PM
12/04/12 08:28 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
BLACK SATIN from Eastwood 1200 degrees
home of the Sox and Martin Hemi Duster
Re: Header Paint ?
[Re: HEMIFRED]
#1345151
12/04/12 08:41 PM
12/04/12 08:41 PM
Posts: 2,648 GA
Boosted
GA
I had mine powder coated.. 150 dollars and still look like new after a full year...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Header Paint ?
[Re: ProSport]
#1345153
12/04/12 09:57 PM
12/04/12 09:57 PM
Butch
Tallmadge, Ohio
That's what I used Bob but I think the header preperation wasn't the best.
