valve stem seals #1344392
12/01/12 12:04 AM
12/01/12 12:04 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
What brand makes the best intake and exhaust valve seals for small block magnums fel-pro? victor reinz? or sealed power? or is there a better brand that i didnt list? I have seen the victor reinz seals and they look of descent qaulity. Never have seen the sealed power seals or fel-pro seals.
Re: valve stem seals [Re: pjc360] #1344393
12/01/12 12:26 AM
12/01/12 12:26 AM
Any name brand will work excellent
Re: valve stem seals [Re: pjc360] #1344394
12/01/12 02:12 AM
12/01/12 02:12 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
For a head that has had the guides machined for additional clearance, I like to use a viton seal. They seem very forgiving, easy to install and dont split like the teflon ones.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: valve stem seals [Re: racealittle] #1344395
12/01/12 12:58 PM
12/01/12 12:58 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
can run viton because the valve would have to come out in order to install them, if i do this i plan on doing it with the engine still in the vehicle. guess now its between fel-pro and victor reinz, for some reason i think the victor reinz are a little better qaulity then the fel pro seals, idk they just look a little better and feel heavier.
