Re: 68gtx paint color?
[Re: 68HemiB]
#1343711
12/01/12 02:21 PM
12/01/12 02:21 PM
Posts: 1,281 WI
wannadrag
WI
[Re: 1_WILD_RT]
#1343716
12/01/12 03:10 PM
12/01/12 03:10 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
PPG is not Chrysler Corp...
They don't list anything like GW-2 which is a legitimate code... The G is the body which would be Green, the W is the roof which would be White & the 2 designates a two tone paint job..
So UU1 is a light blue body & roof....
Actually it's roof first - "G" & body second - "W" (GW2 = white car w/green roof).
[Re: 6bblgt]
#1343719
12/01/12 03:38 PM
12/01/12 03:38 PM
6bblgt
Las Vegas, NV
Here's an original paint Q - "electric blue metallic" in Plymouth speak - trunk compartment. Notice the change in color as coverage lessens into the nooks & crannies. Q is bright & vibrant - U not so much. I bet the teal you are seeing is "oil" leaching from the undercoating? Use some cleaner wax on the windshield jamb or rear wheel tubs where paint is the thickest & it should clear it up in person - the color choices are not that close.
[Re: 68gtx]
#1343720
12/01/12 03:46 PM
12/01/12 03:46 PM
6bblgt
Las Vegas, NV
So my car has a black vinyl top so if it were U code for the paint. Is that all I would have seen just a U by itself?? Thanks Larry J
NO, ion '68 you would still have UU1 on the fender tag/b'cast sheet for "paint & style" they (Chrysler Corp.) didn't concern themselves with vinyl tops at that point in production.
The '68 D & C paint codes are also c-body ONLY. So, L, Q, U are your "only?" logical candidates.
[Re: topside]
#1343726
12/03/12 09:58 AM
12/03/12 09:58 AM
Posts: 6,583 SE Pa.
LimeliteAero
SE Pa.
Nah, I don't have a belief system on it: I figure that's what people see on the tag, and rather than make a production out of explaining tag/paint chart or roof/body - unless asked - oh, never mind.
You are right, you win and I am wrong, OK?
