68 GTX 440 4 speed carb??? #1342260
11/27/12 05:28 PM
11/27/12 05:28 PM
68gtx Offline OP
68gtx  Offline OP
Ok I am restoring a 68 gtx 440 4 speed car. It is a numbers matching car. When I purchased the car it came with a holley 4160. I was told it is correct for this car. However I have done some research and have contacted some people in the know. I have been told a carter 4428s is the correct carb by year one. 1 well known carb shop said it could be a holley 4160, and another shop said it could be either carter or holley(*&^%$^&). Does anyone know for sure without a doubt which carb I need??? Thanks Larry (what carb) Johnson
Re: 68 GTX 440 4 speed carb??? [Re: 68gtx] #1342261
11/27/12 06:04 PM
11/27/12 06:04 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
It should be a Carter AVS 4428. Being that it is a 4speed car, it should have the dashpot attached to the passenger rear. You can see it on this 383 4speed version. It should also have the stubby version of the throttle cable arm, being that there's no kickdown linkage on a 4-speed car.
Troy
Houston Mopar Connection Club
Re: 68 GTX 440 4 speed carb??? [Re: 68gtx] #1342262
11/30/12 10:40 PM
11/30/12 10:40 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
4428s
