B1 ORIGINALS #1341801
11/26/12 07:11 PM
11/26/12 07:11 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Will 1.740" od valvespring cups fit in b1 originals. They appear to be very close to the centre and outer head stud washers.
The cups were supplies by koffels with my valve spring pkg and they advertise they can be machined to 1.750".
any help would be appreciated. Rob
Re: B1 ORIGINALS [Re: 572B1] #1341802
11/26/12 08:45 PM
11/26/12 08:45 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would say yes as I run a 1.625 valve spring. I assume you are talking about inside diameter.
Re: B1 ORIGINALS [Re: camastomcat] #1341803
11/26/12 08:54 PM
11/26/12 08:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No cups on mine but I run a 1.677 valvespring. My guess is yes they shoudl fit but we dont use them with our 1100 open springs.
Re: B1 ORIGINALS [Re: camastomcat] #1341804
11/26/12 09:09 PM
11/26/12 09:09 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
The springs are 1.550" but the cup they sit in has a od of 1.740".
It sounds like most people are using locators under there springs.
Re: B1 ORIGINALS [Re: Al_Alguire] #1341805
11/26/12 09:14 PM
11/26/12 09:14 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Al, maybe it would be easier to just order spring locators, i kind of like the idea of the cups.
The springs are K 1100S.
Re: B1 ORIGINALS [Re: 572B1] #1341806
11/27/12 12:29 AM
11/27/12 12:29 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
won't cups keep the heads from chaffing? or locaters good enough?
Re: B1 ORIGINALS [Re: 72sat] #1341807
11/27/12 03:11 AM
11/27/12 03:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No issues here with no cups. We have well over 500 passes on the heads now. Spring pressure is 1100 open and we use titanium valves, heads look as good as new till. About 100 passes on fresh motor now.
