Re: When is a Pro gearset required? [Re: 340man4ever] #1341611
11/27/12 12:08 PM
11/27/12 12:08 PM
tboomer Offline OP
tboomer  Offline OP
Your new heads have received some "Radar Love"
Yupp...He did mine the same as Jim Van Zees..I talked to Jim and have a little more cam,cubic inches and compression than his Challenger. His does 6.17 in the 1/8th..
Re: When is a Pro gearset required? [Re: tboomer] #1341612
11/27/12 12:16 PM
11/27/12 12:16 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Exactly........a new ball game power wise.....
That things gonna rock
Curator at Adams County Speed Shop
Re: When is a Pro gearset required? [Re: 340man4ever] #1341613
11/27/12 12:25 PM
11/27/12 12:25 PM
tboomer Offline OP
tboomer  Offline OP
I had Radar put all new springs,etc. on. The damned money pit just keeps getting deeper!!
Re: When is a Pro gearset required? [Re: tboomer] #1341614
11/27/12 12:38 PM
11/27/12 12:38 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
I know.....it never ends...$$$$$$$$
You will be happy with the results....Radar rocks!
Re: When is a Pro gearset required? [Re: tboomer] #1341615
11/27/12 01:20 PM
11/27/12 01:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ted just remember to WEED out suggestions from cars that sit in the garage 95% of the time or those from guys that do lots of change-outs. The small difference in price and the fact that you will want them to last forever should lead your direction.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: When is a Pro gearset required? [Re: pittsburghracer] #1341616
11/27/12 01:44 PM
11/27/12 01:44 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
I have never broken a street gear and hope I never do .
I have been running OEM 3.89 gears for hundreds of passes .
3345 lbs
trans break
Spool
35 spline axles.
aluminum strange center section
launch on first stage nitrous
1.36 60 ft
8.95 at 157mph
Re: When is a Pro gearset required? [Re: RADAMX] #1341617
11/27/12 08:44 PM
11/27/12 08:44 PM
Arizona
Chris'sBarracuda Offline
Arizona
3345 lbs
trans break
Spool
35 spline axles.
1.36 60 ft
8.95 at 157mph
Same here.. Street Gear.. 3000# Barracuda.. leaving @ 5800-6200 with a P/G and a brake.. 9.40's to 8.70's (1.23-1.30 60') always a street gear 9" Ford.. No breakage ever. Broke low gear sets before though..
As a matter of fact, the only gear that ever went bad in any of my cars was a pro gear..
Pinks All Out Video.. 9.20's
https://www.youtube.com/watch?v=kCePPblw...mp;feature=plcp
Chris..
Re: When is a Pro gearset required? [Re: Chris'sBarracuda] #1341618
11/27/12 08:49 PM
11/27/12 08:49 PM
tboomer Offline OP
tboomer  Offline OP
Thanks so much,fellas! I had a pretty bad day...But it is getting better! For as many passes as I put on this thing,maybe the standards will work ok...
