cjskotni...I'm trying to set up for worst case scenario if the fans were needed to be at wide open. If I go with this fan idea, I do plan on running the controller Howzywhatsit (sp) has built for it. I haven't checked with him to see if he has a selector type controller for more of a manual/driver's control of the percentage of output (another topic). Good battery is understood.
jbc426... I'm planing on better than stock head lights on relays, but I haven't got to that bridge yet, the rest of the car will be on LEDs. The CS 144 may be what I have to do. A lot of things I've chose to do have pushed me out of the stock look, but I keep trying.
I have read some on the one wire bypass & the 2 wire with the ammeter & bulkhead connecter deal. I ran into that the hard way back in 85-6. I'll try an run extras on relays.
Mad Electric...I've see the name but haven't read there yet,...will have to do that.
