? about the calulaters #1340770
11/24/12 08:23 PM
11/24/12 08:23 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
http://www.summitracing.com/popup/calcsandtools/gear-ratio-calculator
when they ask about the rpm's r they referring to the shift points r your finish line rpm? ............Thax.
Re: ? about the calulaters [Re: racerx] #1340771
11/24/12 08:29 PM
11/24/12 08:29 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Finish line rpm that you will be turning. Don't put in your max rpm because you will not give yourself room to go faster willout overreving the motor
Re: ? about the calulaters [Re: babarracuda] #1340772
11/24/12 08:39 PM
11/24/12 08:39 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax.
Re: ? about the calulaters [Re: racerx] #1340773
11/24/12 09:18 PM
11/24/12 09:18 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
these guys have the most calculaters out there:
http://www.wallaceracing.com/Calculators.htm
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: ? about the calulaters [Re: bigtimeauto] #1340774
11/26/12 12:32 AM
11/26/12 12:32 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax.Bigtime i have that cal.page in my favorites .? for uall i'm looking to change gears next year.The car has 4.57 in it now.The combo is:514cu in.
heads -1's(no port work)
cam. 693/706
conv. 8"
weight 3350/driver
shifting at 6800/trapping at 71-7200.
Using the cal. above it says that an 4.30 gear .What do uall think?...........Thax
Re: ? about the calulaters [Re: racerx] #1340775
11/26/12 12:33 AM
11/26/12 12:33 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
cam. 693/706
conv. 8"
weight 3350/driver
tire size?...
Tony
70 AARCuda Vitamin C
Re: ? about the calulaters [Re: 70AARcuda] #1340776
11/26/12 12:36 AM
11/26/12 12:36 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Sorry.29.5
Re: ? about the calulaters [Re: racerx] #1340777
11/26/12 01:02 AM
11/26/12 01:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your conv slippage(you need to figure that in also)
Re: ? about the calulaters [Re: MR_P_BODY] #1340778
11/26/12 07:33 AM
11/26/12 07:33 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
According to Wallace cal. it's 2.467%..........Thax.
Re: ? about the calulaters [Re: racerx] #1340779
11/27/12 10:05 PM
11/27/12 10:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone?
Re: ? about the calulaters [Re: racerx] #1340780
11/27/12 10:49 PM
11/27/12 10:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you SURE about your trap RPMs .... that is a
SUPER low slippage rate... good is 5% but some get a
little lower
