what does this casting # mean? 40088730-318 3 #1340570
11/24/12 02:42 PM
11/24/12 02:42 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Cast on the side of the block, drivers side.
Re: what does this casting # mean? 40088730-318 3 [Re: flyman] #1340571
11/24/12 03:04 PM
11/24/12 03:04 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
casting #
CID
third revision of the mold when casting
I am truckless..
Re: what does this casting # mean? 40088730-318 3 [Re: 340SHORTY] #1340572
11/24/12 04:30 PM
11/24/12 04:30 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Ok so what year does the # make it?
Re: what does this casting # mean? 40088730-318 3 [Re: flyman] #1340573
11/24/12 04:55 PM
11/24/12 04:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
that casting number was used for multiple years of the 318 after 73 or 74 , the date the engine was cast is on the side of the engine just like that number you posted , plus under the drivers side head there will be a stamped number that will tell you when it was assembled.
