Trouble removing front shocks '69 coronet #1340443
11/24/12 04:23 AM
11/24/12 04:23 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Anyone have trouble removing the front shocks on a '69 B-Body? Car is the R/T convertible with factory sway bars. The lower end of the shock did not want to come out of (or go back into) the lower control arm?
Re: Trouble removing front shocks '69 coronet [Re: 451Mopar] #1340444
11/24/12 10:35 AM
11/24/12 10:35 AM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Yes, I have had them very difficult. but have always got them! compressing the shock and working it front to back is how it worked for me. not a lot of room. I will be removing the origional shocks on my 69 Coronet this winter, as I have a new from end kit ready to install.
Good luck!
Kevin
HEMI,S ARE FOREVER!!!
Re: Trouble removing front shocks '69 coronet [Re: 1969 HEMI R-T] #1340445
11/24/12 10:55 AM
11/24/12 10:55 AM
The sides are usually crushed pretty good so,just slip in a screwdriver underneath and pry upwards.it will come out also spray some silicone in there to help ease it out. Hope this helps.
Re: Trouble removing front shocks '69 coronet #1340446
11/24/12 01:48 PM
11/24/12 01:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
someone got carried away with am impact putting in the last set maybe ???
Re: Trouble removing front shocks '69 coronet [Re: JohnRR] #1340447
11/25/12 02:47 PM
11/25/12 02:47 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I was thinking the location of the stock sway bar mount may have crushed the lower control arm around the shock area? I was able to pound the old shocks out using a long extension through the center of the LCA. I used an adjustable wrench over the shock mounting area to bend it back a bit to make room for the new shocks.
