Re: Starter Engagement
[Re: SpareParts]
#1339953
11/23/12 02:03 AM
11/23/12 02:03 AM
RapidRobert
is the solenoid not kicking the teeth out far enough to engage the flywheel or are the teeth when spinning for whatever reason too far away from the flywheel. Could take off the large cable & jump fire to the small solenoid terminal to move the teeth out so you can see where you're at
[Re: SpareParts]
#1339954
11/23/12 10:38 AM
11/23/12 10:38 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
There;s an odd shaped piece of mounting hardware that comes with the scattershield mounting hardware. It's used on the bottom hole to hold the starter in place. If you look closely in this picture, you can see it in the bottom starter hole. It makes all the difference.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
