Victor Small-Block Chrysler (For LA Engines)
These new Victor Series cylinder heads are for use on 1967-1989, 318-360 c.i. Chrysler LA engines. They feature fully CNC ported 58cc combustion chambers and have an intake port volume of 225cc. These heads are an in-line valve design incorporating a 16° valve angle (stock is 18°) for improved air flow and increased power levels over heavily ported stock versions. They also feature the Chrysler W5 bolt pattern and have raised exhaust ports. The intake port has also been raised approximately 3/4" and the flange has also been extended to accommodate a stock (race) intake manifold such as our Super Victor #2815. Finally, a 5.56" overall length valve (+0.600" from stock) and raised rocker cover permit larger port cross-sections than in the stock head. Four versions are available; bare, bare with valves, complete (for hydraulic/flat tappet cams and solid roller cams) and Pro Port Raw. End-seal spacers are provided.
Combustion chamber volume 58cc
Intake runner volume 225cc
Exhaust runner volume 62cc
Intake valve diameter 2.15"
Exhaust valve diameter 1.60"
Valve stem diameter 11/32"
Valve guides Manganese bronze
Deck thickness 5/8"
Valve spring diameter 1.55"
Valve spring maximum lift .650"
Rocker stud N/A
Guideplate N/A
Pushrod diameter 5/16"
Valve angle 16°
Exhaust port location Raised
Spark plug fitment 14mm x 3/4 reach, gasket seat
Made In USA
This was from their catalog... they have six different part numbers listed: bare, bare wt valves, complete, solid/hyd roller apps, solid roller apps.
None are available.....yet.
I've sold off nearly all my W5 stuff and was ready to be the guinea pig for these, but it's been a long time since they've said they'd be out so I've chosen another path.
