Re: Oil viscosity choice for strip and street
[Re: moparguy7074]
#1338018
11/20/12 04:47 PM
11/20/12 04:47 PM
BradH
Brad, would you know if the RP 5w-30 falls into the same category as M1?
Honestly, I don't pay any attention to Royal Purple or Lucas Oil products since I have no interest in using either brand.
[Re: BradH]
#1338019
11/20/12 06:05 PM
11/20/12 06:05 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Brad ,everyone thanks for the replies and feedback. this saturday will probly be my last meeting till February,except possibly T&T. i will run the 20/50 and over Xmas dyno the motor back to back with the 10/40 . i guess my biggest worry is daily driving/highway use particularly when hot.the last 2 weekend of racing temp has been high 20's and into the 30's Celcius.and its not summer yet.
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1338025
11/26/12 02:56 PM
11/26/12 02:56 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
Tex
Tex, I use Valvoline 5W20wt non synthetic in my Duster, limited street and a lot of strip My bearing clearances are pretty loose, .0035+ on the rods and mains , My oil pressure reads right at 20 lbs at 850 RPM in gear with oil temps at or above 180F on the street 1200 RPM makes the oil pressure go up to 35 lbs and it has 50 lbs at 1500 RPM, 65 lbs at 7000 RPM There is some HP gains with low oil temps with the lightweight oils is what I found years ago, just what most bracket racers need
[Re: Cab_Burge]
#1338026
11/26/12 06:05 PM
11/26/12 06:05 PM
tex013
Sydney,Australia
UOP,Cab ,Greg thanks for all replies. much to ponder. Greg i turn around 6300-6400 through the traps and have a deep sump.hopefully that should stop aeration etc on launch. Cab i drive the car every day so we will see with the 10-40.a few more hp won't hurt by the way it was in the 90's on saturday at the races thanks all
Tex
[Re: tex013]
#1338027
11/26/12 06:18 PM
11/26/12 06:18 PM
Cab_Burge
I probally should state the HP gain versus losses results on thin multiweight oil versus straight wt. oils are based on a dyno tests that I did years ago. I was dyno testing the first motor I built for a customer who wanted it dyno tested and tuned, it was 1962 Dodge 390 HP 413 M.W. I broke the motor in on straight 30 WT Valvoline non detergent oil and then switched it to detergent 30 WT Valvoline, I was seeing a 10 HP gain on oil temps between 130F versus 160F + the hotter I got the oil temps(up to 190 F, no gains seen after that hot) before starting the pull the more HP it would make I later switch on other motors to using Valvoline 10W30WT multi grade and then to 5W30 and finally at 5W20WT, I saw no HP or torque gains based on oil temps on the lighter weight multi viscosity oils All the motors I tried doing pulls at 120 F with multi weight oils versus at or above 160F with the same motor and oil saw no measurable HP or torque gains For you bracket racers that see your cars pickup when hot lapping, what type and weights of oil do you use
[Re: VernMotor]
#1338029
11/27/12 01:12 AM
11/27/12 01:12 AM
tex013
Sydney,Australia
thanks Vern, i know what you mean re all things adding up.i'm licky i get a good heat soak/cycle driving out to the track
Tex
[Re: VernMotor]
#1338030
11/27/12 01:42 AM
11/27/12 01:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
"you bracket racers that see your cars pickup when hot lapping, what type and weights of oil do you use"
Yes my car will pick up but I do not think it is oil temps. You have trans temps- rear end -wheel bearing-motor get heat in it and burns fuel better. I run 15-40 wt oil. all these things together make it pick up.
My first pass of the day is always a bit slower... thats with driving it around to warm it up
[Re: MR_P_BODY]
#1338031
11/27/12 04:12 PM
11/27/12 04:12 PM
Cab_Burge
I try to drive my car around enough before racing it at the track to get the oil and trans. temps. up to at least 130F, I run 75-90 WT gear oil in the rear and I do not have a temp. gauge in it so I don't have any idea what it runs at My car does not vary more than .02 on the ET from first run to last run, early morning to late afternoon,(unless the track is bad)5W20Wt motor oil
[Re: Cab_Burge]
#1338032
11/27/12 05:51 PM
11/27/12 05:51 PM
tex013
Sydney,Australia
MrP, my first pass is often the slowest - must need to blow the cobwebs out Cab,i wish my spread was so tight though with the 825 md it does seem more sensitive to da change.may have to go back to the prosystems hp1000 based carb
Tex
