Removing 727 From 340 Question
#1337745
11/19/12 01:46 PM
11/19/12 01:46 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
It has been 7+ years since I last pulled my 727 out of the car, and I have forgotten if I had to support the rear of the engine or not as I unbolt the tranny. Can someone confirm this for me? If so, where is a good place? Thanks allot!!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Removing 727 From 340 Question
[Re: YO7_A66]
#1337746
11/19/12 01:51 PM
11/19/12 01:51 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Yes, absolutely support it. Either something under the oil pan, towards the back, or a strong board up between the fender ledges with some chain, etc. use rags, blocks etc to save paint/oil pan. Definitely support it.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: VincentVega]
#1337747
11/19/12 01:56 PM
11/19/12 01:56 PM
YO7_A66
Indiana
Can I put a floor jack with a 2x4 piece of wood under the oil pan or will this damage the oil pan?
Thanks for your response.
[Re: YO7_A66]
#1337748
11/19/12 02:01 PM
11/19/12 02:01 PM
VincentVega
Northeast
You might be able to get away with that. I don't do that though. hydraulic floor jacks many times leak down especially if they are older. I always like doing something solid, even if it's a chunk of 4x4 stood up, or a pile of bricks, a concrete block stood up with something on top. You're not talking about more than a few hundred pounds at worst, you just want some stability in what you create.
[Re: VincentVega]
#1337749
11/19/12 02:13 PM
11/19/12 02:13 PM
YO7_A66
Indiana
Got it. I will make something out of wood so I can use my second jack if needed.
thanks again!!
[Re: YO7_A66]
#1337750
11/21/12 08:49 AM
11/21/12 08:49 AM
YO7_A66
Indiana
Finding a place under my 340 for an engine support has been tough. The only place that I found was the oil pan "flange". I cut two pieces of 1-1/2" square aluminum extrusion and placed one end under the oil pan flange (on both sides of the pan) and then let the other ends rest on a 1/2" piece of hardwood on the floor. The engine and tranny are now resting on these two rails, but I am curious how others have supported their small blocks from underneath when pulling their tranny's. Any pictures? Thanks
[Re: 1_WILD_RT]
#1337755
11/21/12 12:20 PM
11/21/12 12:20 PM
YO7_A66
Indiana
While I was getting the lengths of my engine supports correct, I lowered the tranny down too much and I had no support under the tranny or the engine. The tranny/engine just hung there with only the engine mounts. I only did this for a couple of minutes and then I put the supports under the pan flange.
I then wondered what it would hurt if there were no supports under the engine once the tranny was off. I assumed that the engine would have pivoted farther down than it did and this surprised me. My concern is that the tranny will be at the shop for a few weeks and I did not want the engine just hanging there while I was doing some other cleanup work under the car. Thanks for the replies!!
[Re: buildanother]
#1337757
11/21/12 02:05 PM
11/21/12 02:05 PM
YO7_A66
Indiana
I just received a hint from my tranny guy to use the steering drag link as a support after the tranny is removed. If I remember right, there is about an inch or so clearance between the bottom of the pan and the drag link. I may stick a wood spacer in there and give that a shot. This would give me more room to move around under the car and not to have to worry about knocking into a support post.
[Re: YO7_A66]
#1337759
11/22/12 01:44 AM
11/22/12 01:44 AM
Posts: 828 Winchester, In
tippytoe
Winchester, In
I have done that many times. Works great for me.
[Re: Cab_Burge]
#1337761
11/22/12 08:32 PM
11/22/12 08:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I seem to remember putting a 2x4 between the rocker covers and fire wall. One more cat skun.
I have mechanical Aptitude. I can screw up anything.
