Gen3 question 6.1
#1337273
11/18/12 05:48 PM
11/18/12 05:48 PM
Garry Owen
Looking for some recommendations on a cam. It's not going to be a track car, but I do want a healthy cam. Where I want to end up is a something that will kill on the street but still have some get up on the highway. I'm a cheap [Edited by Moparts - Family Friendly Site - Keep it clean] so I've layed out some end items to base the cam question and ptv clearance. End product will be an airhammer cai, heartthrob catback, tranzformer, 180 thermostat, udp, and 11.1 compression and a cam with tune. So there's the basic "what cam?" question but also what's the best route with bumping up the compression? Thinner gasket or milling the heads, and the ptv issues that might show up with said cam. Thanks in advance
I asked this on lxforums but wound up getting the basic vendor call me answer. I really want to know what issues I would run into with milling the heads or thinner gasket to increase compression. I don't want to notch the pistons, due to budget. Is this even possible and could there be a cam to run in it?
Re: Gen3 question 6.1
[Re: MattW]
#1337275
11/18/12 06:06 PM
11/18/12 06:06 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
HHP offers some BES designed grinds in stage 1,2 and 2r.
Mopar to the bone!!!
[Re: AlexP]
#1337283
11/20/12 05:51 PM
11/20/12 05:51 PM
Posts: 4,255 Canada
WO23Coronet
Canada
DO NOT MILL 6.1 HEADS.
You only need to run something about a 219/223. That has taken LX's into the low 11's with heads
The 6.1 doesn't need the higher compression. You can't run bigger than about 223/227 without running into serious piston to valve clearance issues.
When u day not to mill 6.1 heads is it because the decks are to thin? Or does it take away to much piston to valve clearance? Also, why does the Gen III get noisy valve train if you mess with the geometry? Sorry for the rapid fire questions just trying to learn about these engines
[Re: WO23Coronet]
#1337284
11/20/12 06:00 PM
11/20/12 06:00 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
1. 6.1 heads are expensive and not getting any cheaper. No reason to cut them. There is plenty of room and material to tailor compression in there without cutting the deck.
2. They aren't thin. Only the 5.7 eagle is thin in a few spots, but nothing really critical.
3. Most all hemi cams are ground on a 6.1 base circle. To compensate, a 5.7 block with a 6.1 cam would use 6.1 pushrods as a general rule of thumb to prevent uncessesary lifter movement.
[Re: Garry Owen]
#1337288
11/20/12 07:41 PM
11/20/12 07:41 PM
AlexP
Houston, Tx
Tracking. I have a few tuners in mind right now.
Jerseyboy, Hemituner and lafrad all come to mind as really good tuners.
[Re: AlexP]
#1337289
11/20/12 08:30 PM
11/20/12 08:30 PM
Garry Owen
Those and I heard Johan is pretty decent.
[Re: AlexP]
#1337290
11/20/12 11:24 PM
11/20/12 11:24 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Just wanted to say great info - and kudos for helping the OP out...I have been reading the "run around" he was getting on the other forum.
[Re: Moparmal]
#1337291
11/21/12 12:26 AM
11/21/12 12:26 AM
Garry Owen
Well, I guess some message boards aren't for messaging.If I wanted to just call vendors I would have to start with. I was trying to reach out to the end user or someone who had tried something similar. I know there's some good guys over and some that are on both boards, that's why I threw out the question both places. Other than buying parts, I think I'll stick with moparts for answers.
