97 Stratus Heat Selector Switch Question? #133719
10/08/08 02:17 AM
10/08/08 02:17 AM
Middle of the mitten
69DodgeCharger Offline OP
The heater/blower system on my 97 Stratus will only blow through the defrost vents no matter where the selector switch is. Anybody had this problem and if so how did you fix it.
Re: 97 Stratus Heat Selector Switch Question? [Re: 69DodgeCharger] #133720
10/08/08 01:35 PM
10/08/08 01:35 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
That should be vacuum operated, if so make sure that your connection from engine compartment did not come loose, or that the unit is leaking at the selector switch.
