The dreaded "pick a cam for me" thread. **Update**
#1336273
11/16/12 09:13 PM
11/16/12 09:13 PM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
1971 Satellite 383 block, .030" over, stock stroke Forged pistons .021" in the hole Stock 906 heads, new springs with dampners (Pioneer rv891x) 8.80:1 measured compression 727 2.76.1 or 3.23:1 rear end DP4B dual plane intake 650 Eddy carb HP exhaust manifolds power brakes air conditioning
This will be a 100% street car and will never see anything over 4000 rpm. I need vacuum for brakes and vacuum controlled dash/heater box. I want to run a/c and have it get decent mpg (I'm guessing 16-17???).
What cam to use?
Re: The dreaded "pick a cam for me" thread. well, which one
[Re: VITC_GTX]
#1336274
11/16/12 10:43 PM
11/16/12 10:43 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Probably about the easiest cam question there is. You could go with a stock cam, no problem.
Check out crane grind # H-260-2 that's actually a little weaker than stock, and will have a tremendous bottom end. 112 LSA so it'll have a good idle and lots of vacuum.
Personally I'd go with a modern/stock equivalent grind, so you could at least wind up and be satisfied if you wanted to.
Seriously, any stock replacement came or the so-called RV cams will work great for what you want.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: 6PACMAC]
#1336276
11/16/12 10:53 PM
11/16/12 10:53 PM
6401 Summit Cam is an amazing grind perfect for your application--383's need lots less cam than others that unit will idle well still sound Good, Melt tires off idle and pull like a train to about 5000 what more do ya want? And it is CHEAP!!!!!!!!!! I have used that cam in over 30 big mopars--it rocks for street applications with low to med compression like yours--trust me -it is an amazing camshaft 224 234 460?/ 488 exh lift I would install it around 102-103 with gears you plan it is PERFECT!
[Re: VITC_GTX]
#1336277
11/17/12 01:01 AM
11/17/12 01:01 AM
Posts: 1,012 indiana
mcmopars
indiana
What cam to use?
nothing above 4000?in a mopar?are you serious?hell they make hondas for that.im not knocking you but come on.if i had a 71 hemi cuda convertible id air it out now and again.i just cant help myself.dont have a cam choice for you,it just struck me odd on your post.happy hunting on your cam.
[Re: Mr.Yuck]
#1336281
11/17/12 11:33 AM
11/17/12 11:33 AM
I have used it with smogger shortblocks all the way to true 10:1 Yea more compression runs better but his application will work great with that cam advanced a little like I mentioned---It will run fine with less CR than they advertise--they gotta put something in that blank--the 6401 will sound great yet is not too big to kill it --it runs like a much smaller cam IMO I usually install it at about 105 in a higher compression and around 102 in lower with fantasic results--best street cam ever for CHEAP
[Re: BSB67]
#1336283
11/17/12 12:40 PM
11/17/12 12:40 PM
My pick is $62 Others are near $150 duh.....
[Re: 6PakBee]
#1336284
11/17/12 12:46 PM
11/17/12 12:46 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I looked at that cam and they are recommending a minimum CR of 9.5:1. What ratios have you used this with, specifically what do you mean by "low to med compression"?
I am using the 6401 in my 440, and I agree. It is an awesome cam in my relatively stock build, but I have 9.35:1 static compression. I went around and around with this also because it was less than 9.5:1. They determined that a point and a half wasn't enough to worry about. 8.8:1 may be though. I would try to bump up the compression or pick a stock cam as mentioned. It will definitely run good with the 6401, but you may be leaving some HP/TQ on the table compared to others.
[Re: dangina]
#1336286
11/18/12 02:44 PM
11/18/12 02:44 PM
mcmopars
indiana
have you looked at the hughes whiplash cam series?
he wont need one of these,it will never see 4 grand.
[Re: VITC_GTX]
#1336288
11/18/12 10:50 PM
11/18/12 10:50 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Not that I know anything, but Summit 6401 seems like a big cam for low compression 383 with 2.73. No mention of transmission.
68 Roadrunner. 383 4-spd. Beat up.
[Re: RapidRobert]
#1336290
11/19/12 09:18 AM
11/19/12 09:18 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
http://www.summitracing.com/parts/LUN-60300LK/http://www.summitracing.com/parts/LUN-60301I'd go with the voodoo 60300 or 60301..... apples and fruit loops, but I had a similar duration hydraulic roller in a 9:1 magnum headed 318, pulled real good from idle to about 5500 RPM, plenty of vacuum for brakes and A/C
