The dreaded "pick a cam for me" thread. **Update** #1336273
11/16/12 09:13 PM
11/16/12 09:13 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
1971 Satellite
383 block, .030" over, stock stroke
Forged pistons .021" in the hole
Stock 906 heads, new springs with dampners (Pioneer rv891x)
8.80:1 measured compression
727
2.76.1 or 3.23:1 rear end
DP4B dual plane intake
650 Eddy carb
HP exhaust manifolds
power brakes
air conditioning
This will be a 100% street car and will never see anything over 4000 rpm. I need vacuum for brakes and vacuum controlled dash/heater box. I want to run a/c and have it get decent mpg (I'm guessing 16-17???).
What cam to use?
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336274
11/16/12 10:43 PM
11/16/12 10:43 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Probably about the easiest cam question there is. You could go with a stock cam, no problem.
Check out crane grind # H-260-2 that's actually a little weaker than stock, and will have a tremendous bottom end. 112 LSA so it'll have a good idle and lots of vacuum.
Personally I'd go with a modern/stock equivalent grind, so you could at least wind up and be satisfied if you wanted to.
Seriously, any stock replacement came or the so-called RV cams will work great for what you want.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336275
11/16/12 10:45 PM
11/16/12 10:45 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
You know they say "never say never" . But if you really are just gonna putt around, any small, off shelf, hyd cam will do. Imo. With 2.76s, you might hit 18-20 mpg on the highway.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: 6PACMAC] #1336276
11/16/12 10:53 PM
11/16/12 10:53 PM
6401 Summit Cam is an amazing grind perfect for your application--383's need lots less cam than others that unit will idle well still sound Good, Melt tires off idle and pull like a train to about 5000 what more do ya want? And it is CHEAP!!!!!!!!!! I have used that cam in over 30 big mopars--it rocks for street applications with low to med compression like yours--trust me -it is an amazing camshaft 224 234 460?/ 488 exh lift I would install it around 102-103 with gears you plan it is PERFECT!
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336277
11/17/12 01:01 AM
11/17/12 01:01 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
1971 Satellite
727
650 Eddy carb
power brakes
air conditioning
What cam to use?
nothing above 4000?in a mopar?are you serious?hell they make hondas for that.im not knocking you but come on.if i had a 71 hemi cuda convertible id air it out now and again.i just cant help myself.dont have a cam choice for you,it just struck me odd on your post.happy hunting on your cam.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: ] #1336278
11/17/12 10:02 AM
11/17/12 10:02 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I looked at that cam and they are recommending a minimum CR of 9.5:1. What ratios have you used this with, specifically what do you mean by "low to med compression"?
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336279
11/17/12 10:39 AM
11/17/12 10:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well no doubt you will see 4000+, just a guess. As for cam with those weeeeeeeeeek gears I'd go w/ the small summit cam or the old mopar 455 or comp cams 447/455 cam. You do know that going up to 3.23 gears won't make your MPG any worse right? If you want max mpg you'll need a sixpack, but 16 is doable if you keep your right foot nice and easy. Headers would also help w/ mileage and give you 15-20 more HP.
Coming soon!!!!
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Mr.Yuck] #1336280
11/17/12 11:30 AM
11/17/12 11:30 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
comp cams magnum replacement cam part number 21-305-4 (this cam makes good low speed torque), or the mopar 272-.455 (nice torquey driver cam).
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Mr.Yuck] #1336281
11/17/12 11:33 AM
11/17/12 11:33 AM
I have used it with smogger shortblocks all the way to true 10:1 Yea more compression runs better but his application will work great with that cam advanced a little like I mentioned---It will run fine with less CR than they advertise--they gotta put something in that blank--the 6401 will sound great yet is not too big to kill it --it runs like a much smaller cam IMO I usually install it at about 105 in a higher compression and around 102 in lower with fantasic results--best street cam ever for CHEAP
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336282
11/17/12 11:33 AM
11/17/12 11:33 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
For your low expectations, any small cam will do.
Just to deviate from the popular choices, I would look at the Crower 32241. I comes with a 112 LSA and 46 dregrees overlap. Its idle characteristics will be vey close to stock. Its lobe rates are more agressive than the factory stuff, less agressive than the Comp XE-H and Voodoo.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: BSB67] #1336283
11/17/12 12:40 PM
11/17/12 12:40 PM
My pick is $62
Others are near $150 duh.....
Re: The dreaded "pick a cam for me" thread. well, which one [Re: 6PakBee] #1336284
11/17/12 12:46 PM
11/17/12 12:46 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I am using the 6401 in my 440, and I agree. It is an awesome cam in my relatively stock build, but I have 9.35:1 static compression. I went around and around with this also because it was less than 9.5:1. They determined that a point and a half wasn't enough to worry about. 8.8:1 may be though. I would try to bump up the compression or pick a stock cam as mentioned. It will definitely run good with the 6401, but you may be leaving some HP/TQ on the table compared to others.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: bobs66440] #1336285
11/18/12 12:11 PM
11/18/12 12:11 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
have you looked at the hughes whiplash cam series?
Re: The dreaded "pick a cam for me" thread. well, which one [Re: dangina] #1336286
11/18/12 02:44 PM
11/18/12 02:44 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
he wont need one of these,it will never see 4 grand.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: dangina] #1336287
11/18/12 02:45 PM
11/18/12 02:45 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
I agree with Crabman, for your requirements the Summit cam would be perfect and it is on sale for only $58!! I am going to buy one just to keep in stock!
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336288
11/18/12 10:50 PM
11/18/12 10:50 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Not that I know anything, but Summit 6401 seems like a big cam for low compression 383 with 2.73. No mention of transmission.
68 Roadrunner. 383 4-spd. Beat up.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Mebsuta] #1336289
11/19/12 12:04 AM
11/19/12 12:04 AM
My thoughts too. I'd go with the Summit 6400. I'm assuming it is the same (cheap) price. I was thinking someone also said the 6401 needs a high(er) stall
Re: The dreaded "pick a cam for me" thread. well, which one [Re: RapidRobert] #1336290
11/19/12 09:18 AM
11/19/12 09:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
http://www.summitracing.com/parts/LUN-60300LK/
http://www.summitracing.com/parts/LUN-60301
I'd go with the voodoo 60300 or 60301.....
apples and fruit loops, but I had a similar duration hydraulic roller in a 9:1 magnum headed 318, pulled real good from idle to about 5500 RPM, plenty of vacuum for brakes and A/C
2017 Grand Cherokee Overland
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336291
12/09/12 01:14 AM
12/09/12 01:14 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I ended up buying the smaller Summit cam (6400, not the 6401). Here are the specs, anyone see a problem in using this cam?
Summit Racing Part Number: SUM-K6400
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-5,000
Duration at 050 inch Lift: 214 int./224 exh.
Advertised Duration: 272 int./282 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.442 int./0.465 exh.
Lobe Separation (degrees): 112
Camshaft Gear Attachment: 1-bolt
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336292
12/09/12 01:22 AM
12/09/12 01:22 AM
not me, you'll be fine
