Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... #1335070
11/14/12 04:25 AM
11/14/12 04:25 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Anyone using them for a street/strip big cube Hemi and where's the best place/deals to get em?
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: LAD 524] #1335071
11/14/12 02:39 PM
11/14/12 02:39 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I use them all the time. Get them directly from Eric at Stage-V. The only issue is that the higher exhaust ratio moves the pushrod toward the bore so plan on doing some grinding. But that's typical with a HEMI.
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: Mopar_Rich] #1335072
11/15/12 10:32 AM
11/15/12 10:32 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx for the heads up Rich....I'll email Eric. Any idea what 8 sell for?
My combo uses ported Legend 426-1 heads, Indy shafts/hold downs and has Stage V 1.6 intakes and in due course was looking to grab a set of 1.6 exhausts as well.
I'll keep an eye on the pushrod gole clearance, is there any other issues swapping out the wide pads for the Stage Vs ?
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: LAD 524] #1335073
11/15/12 11:34 AM
11/15/12 11:34 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The pushrod issue is the reason that different exhaust rockers are typically used. It can create a major problem. I would think twice before doing it, and definitely mock it up first.
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: Mopar_Rich] #1335074
11/15/12 11:58 AM
11/15/12 11:58 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thx for the heads up Rich
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: Mopar_Rich] #1335075
11/15/12 12:06 PM
11/15/12 12:06 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
X2
And preferably with a head gasket as well. I have seen those hit the push rods too.
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: Dragula] #1335076
11/15/12 09:32 PM
11/15/12 09:32 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Just wondering how well those wide pads will hold up.......
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: LAD 524] #1335077
11/15/12 10:14 PM
11/15/12 10:14 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
What pads? The rockers are roller tips. And you must use lash caps.
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: Mopar_Rich] #1335078
11/16/12 07:43 AM
11/16/12 07:43 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The crower caps were too short, I got some from Comp, they fit over the valve stem better. Tim
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: astjp2] #1335079
11/16/12 10:00 AM
11/16/12 10:00 AM
an8sec70cuda Offline
Make sure you measure the depth the lash caps sit over the valve. I had some from Comp that were actually sitting on top of the locks, not on top the valve. They were too deep, had to trim em down and they work fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi guys.....Stage V HEMI 1.6 exhaust rockers..... [Re: an8sec70cuda] #1335080
11/16/12 11:05 AM
11/16/12 11:05 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Chip, I had to trim mine down .010" to clear the locks as well
