Re: 4.15 stroke HEMI [Re: 23T Hemmee] #1334602
11/18/12 06:30 PM
11/18/12 06:30 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
thanks for the advice. We only run n roadcourses, so a short track cam would probably be the best choice. However, as there are that many cubes, I'd be tempted to run a profile with more duration and more overlap.
At Le Mans we run a 2.80:1 rear and top speed is 180+ mph. At Monza and Spa we run a 3.15:1 rear and at the Nürburgring GP track a 3.64:1
Weight with me inside an half a tank of gas is 3850 lbs
Re: 4.15 stroke HEMI [Re: 23T Hemmee] #1334603
11/22/12 12:58 PM
11/22/12 12:58 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
we checked stroke again and found that it is in fact a 4.15".
With that, we have 7.1" Oliver rods and 4.28" custom made JE pistons. The other quite cool things that we found is that the block a vintage HEMI block from 1969 and the alloy heads are 2531110 originals
Re: 4.15 stroke HEMI [Re: docford] #1334604
12/02/12 02:56 PM
12/02/12 02:56 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
heads and block have -M at the end of their casting number, so they are not from back in the day, but recasts from Mopar Performance
