Re: Superbird needs body and paint question?
[Re: Golden-Arm]
#1334254
11/16/12 10:40 AM
11/16/12 10:40 AM
Posts: 42 Ontario, Canada
GTX fan
Ontario, Canada
call le hodge, and see what his schedule is like. if you just need a roller prepped and painted, it shouldnt be a 4 year wait.
I agree. You owe it to yourself to talk to Le Hodge. Hodge Restorations is a MOPAR only shop. www.hodgerestorations.com
[Re: GTX fan]
#1334255
11/16/12 02:31 PM
11/16/12 02:31 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think it all depends on what the end result is that you want. If you want a valuable , fully restored car that you're afraid to drive then you have to bite the bullet and spend the big bucks. On the other hand, if you want a really nice driver done with less expense but stillhaving a good resale value down the road then I'd suggest you take things a little further yourself. Keep in mind there is a small market for expensive, perfect cars.
Take it down to the bare shell yourself. If it needs any sheet metal work, find someone that is good locally and have that done. Before any bondo, etc. Have the thing totally blasted. Some places will epoxy prime afterwards but in not, invest in a good airless spray system and prime it yourself. Then use a single stage paint and do things like the interior, trunk, underside, engine compartment, etc. yourself. Now send it out for any bondo it needs. At this point you may be comfortable with the spray gun and decide to paint yourself. Base/clear can be forgiving. The end result may not be "perfect" but will likely have a higher return on investment that an all out restoration - which you've already said is not in your budget.
[Re: beatgoeson]
#1334257
11/16/12 09:51 PM
11/16/12 09:51 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
Beatgoeson, Check out these guys. Clark Classic Restorations I brought them my 68 Hemi Road Runner as a primered shell and got it back very red... I also had them paint a few of the interior parts that were black and my steel rims. I gave them enough of the seals, latches and bumpers needed to hang the doors and install the hood and deck lid. At the website, click on Partial Restorations and scroll down to see "Jim's 68 Hemi Road Runner" Do not let the distance from Maryland hold you from selecting a good shop.
