Re: BB with headers..... [Re: Robbins] #1333370
05/22/13 12:01 PM
05/22/13 12:01 PM
dogdays Offline
dogdays  Offline
Rick MAKES Firecore, or at least has them made.
R.
Since Prestolite now owns Accel, as well as jacobs and mallory, you can buy Accel wires with the ceramic boots that may be a help.
Re: BB with headers..... [Re: dogdays] #1333371
05/28/13 07:39 AM
05/28/13 07:39 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Throw some protective sleeves on those spark plugs and that should keep the wires away from the headers. S/F.....Ken M
Re: BB with headers..... [Re: EchoSixMike] #1333372
05/28/13 08:40 AM
05/28/13 08:40 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
It may help to get some short spark plugs like some lawn mowers use..
I am truckless..
Re: BB with headers..... [Re: 340SHORTY] #1333373
05/28/13 09:08 AM
05/28/13 09:08 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I was reading up on that when I got these wires. I've read that some people are having good luck with that. Does anybody have a part number on those?
I was going to try and contact MSD to see what there tech's say.............but right know I'm knee deep on trying to finish my new 3000 sq. ft. shop out so that I can work out of it.
Trust me..........I would rather being playing....I'm still needing to finish working out the accelerator pump shot on the six pack in the Valiant out too.
Thanks for the replies guys.
Moparlee
Re: BB with headers..... [Re: Robbins] #1333374
06/08/13 10:34 AM
06/08/13 10:34 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
MSD tech dude was saying to buy another set and put this shrink stuff over it. summit msd parts
You guys ever use this stuff?
Moparlee
Re: BB with headers..... [Re: Robbins] #1333375
06/12/13 02:28 AM
06/12/13 02:28 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
With straight plug heads I had to put a good sized dent in #5 tube for the plug to clear properly and for there to be ANY clearance for the plug wire. I ended up using the boot insulators that slip over the wire and look like header wrap. It works for awhile but eventually it still burns up the wire end. Always #5. I think if I had angle plug heads it'd clear better but it looks like it'd make one of the other cylinders tighter.
This is what I'm using. http://www.summitracing.com/parts/the-14260
I had cardboard in front of the radiator this winter to keep the heater working better and it caused the plug wire to burn a lot faster. Since I took the cardboard out, no more problems. So far. May have to build my own headers eventually. Probably when I finish these Stage VI heads.
Re: BB with headers..... [Re: dodgeboy11] #1333376
06/12/13 10:30 AM
06/12/13 10:30 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Hey I appreciate the feed back. I think that I'm going to try what you posted over the stuff MSD said and see if can't over kill it.
What do you guys think?
Anybody have the part number for the shorter plugs that work. I wish that I could find that again. Someone had posted that on another mopar site.
Moparlee
Re: BB with headers..... [Re: Robbins] #1333377
06/12/13 03:31 PM
06/12/13 03:31 PM
dogdays Offline
dogdays  Offline
Just got done watching an old Popular Hot Rodding video on headers, find the link on the Race engine page, there was something like 600 degrees F difference between ceramic coated and black painted headers. Something to think about.....Oh, and shorty headers are inferior to long tubes over the entire rev range (except for one point where they matched).
R.
Re: BB with headers..... [Re: dogdays] #1333378
06/13/13 11:10 AM
06/13/13 11:10 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I had to run the "peanut" plugs on my 440 in the Ramcharger with headers.
Summit and Jegs sell them.
http://www.summitracing.com/parts/acc-0574s-4/overview/make/dodge
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: BB with headers..... [Re: hp383] #1333379
06/13/13 12:05 PM
06/13/13 12:05 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Hey thanks for the feed back...........will these fit 915 heads?
Moparlee
Re: BB with headers..... [Re: Robbins] #1333380
06/13/13 12:18 PM
06/13/13 12:18 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Do the 915's use a flat seat with the crush washer, or are they a taper seat?
If they are the flat seat they should work.
If they are a taper seat you could look at maybe the Chevy type peanut plug. I think they used a taper seat.
Re: BB with headers..... [Re: hp383] #1333381
06/13/13 12:54 PM
06/13/13 12:54 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok, I'm going to have to pull a plug cause right now I'm not remembering off the top of my head. Thanks again for the part number.
Moparlee
