BB with headers.....
#1333350
11/10/12 06:32 PM
11/10/12 06:32 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
............what spark plug wires are you guys running with good luck? Mine are jumping fire to the headers....bought a cheap Autozone set and they are doing the same thing.
Moparlee
Re: BB with headers.....
[Re: rickstershemi]
#1333355
11/11/12 12:42 PM
11/11/12 12:42 PM
Robbins
Joplin, MO USA
Thanks guys. I don't know what I was thinking really....in my mind it wasn't going to be a hot rod/go fast truck so I was hoping stock stuff would work, but......anyways thanks for the feed back.
Moparlee
[Re: Robbins]
#1333356
11/11/12 04:04 PM
11/11/12 04:04 PM
Robbins
Joplin, MO USA
I ordered some street fires, today. We'll see how the fit. Thanks again everybody.
Moparlee
[Re: Hemi_Ram]
#1333362
11/13/12 12:48 AM
11/13/12 12:48 AM
Robbins
Joplin, MO USA
I'm not seeing that on there website, the coil I'm running is the mopar looking one. That looks like an e-coil style. I'm being thinking of running on of those.
Moparlee
[Re: Hemi_Ram]
#1333366
11/13/12 10:54 PM
11/13/12 10:54 PM
Robbins
Joplin, MO USA
Ok if you don't mind, what is the dimensions of that coil.....how big of foot print does it have?
Moparlee
[Re: Hemi_Ram]
#1333368
11/15/12 01:11 AM
11/15/12 01:11 AM
Robbins
Joplin, MO USA
I wonder how hard it would be to mount that on my six pack coil bracket that I'm using. Thanks for the close up.
Moparlee
[Re: Robbins]
#1333369
05/21/13 10:00 PM
05/21/13 10:00 PM
Robbins
Joplin, MO USA
Well that didn't last long Number five is jumping fire again.
Moparlee
[Re: Robbins]
#1333375
06/12/13 02:28 AM
06/12/13 02:28 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
With straight plug heads I had to put a good sized dent in #5 tube for the plug to clear properly and for there to be ANY clearance for the plug wire. I ended up using the boot insulators that slip over the wire and look like header wrap. It works for awhile but eventually it still burns up the wire end. Always #5. I think if I had angle plug heads it'd clear better but it looks like it'd make one of the other cylinders tighter. This is what I'm using. http://www.summitracing.com/parts/the-14260I had cardboard in front of the radiator this winter to keep the heater working better and it caused the plug wire to burn a lot faster. Since I took the cardboard out, no more problems. So far. May have to build my own headers eventually. Probably when I finish these Stage VI heads.
[Re: dodgeboy11]
#1333376
06/12/13 10:30 AM
06/12/13 10:30 AM
Robbins
Joplin, MO USA
Hey I appreciate the feed back. I think that I'm going to try what you posted over the stuff MSD said and see if can't over kill it.
What do you guys think?
Anybody have the part number for the shorter plugs that work. I wish that I could find that again. Someone had posted that on another mopar site.
Moparlee
[Re: hp383]
#1333379
06/13/13 12:05 PM
06/13/13 12:05 PM
Robbins
Joplin, MO USA
Hey thanks for the feed back...........will these fit 915 heads?
Moparlee
[Re: Robbins]
#1333380
06/13/13 12:18 PM
06/13/13 12:18 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Do the 915's use a flat seat with the crush washer, or are they a taper seat?
If they are the flat seat they should work.
If they are a taper seat you could look at maybe the Chevy type peanut plug. I think they used a taper seat.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1333381
06/13/13 12:54 PM
06/13/13 12:54 PM
Robbins
Joplin, MO USA
Ok, I'm going to have to pull a plug cause right now I'm not remembering off the top of my head. Thanks again for the part number.
Moparlee
