Demon plans.
Car started out as a Strip only car, but won't be hard to return to the street.
Ladder bar out back, sub-frames tied 6 point cage were already in it at purchase.
440 stroked to 512 is the plan. We are looking at the whole Crate Motor vs. Putting one together. Local machine shops all like Chevy's so we are looking for recommendations on the motor.
Cope Racing Transmission 727 with Gear Vendors overdrive.
Back Braced 8 3/4 rear, narrowed 3 inches, with 4:30 Gears.
Wheel wells mini-tubbed and quarter panels opened up to get 31.5in Dia. Tires under it out back.
4 wheel disc brakes. Willwoods up front with Dr. Diff's out back.
Dual EZ EFI throttle bodies.
Magnum Force Front end, Magnum's shock braces along with some thoughts we have have had for additional bracing.
I will look for some images of the car right after we got it
Thanks for your interest.
